WestCoast96Z28
12-20-2007, 03:38 PM
So, going to finally do the LS1 brake upgrade this weekend. I've searched/read through the threads. I've looked at the procedure in the Fbody.com install guide.
But I have one question before I start. After you take the 3 castle nuts off the spindle..is there a lot of spring tension from the upper/lower A-arms squeezing the spindle in place. Looking at the pictures, would the front shock/spring keep the spindle compressed, or could I just spread the A-arms to take the spindle out without using some special tool to keep them separated?
Also, any other tricks/roadblocks would be appreciated. I hear about soaking the castle nuts in WD40 first...anything else?
