Is there a different Spohn tq arm for 12 bolts?
97s10ondubs
12-15-2007, 06:17 PM
I figured since the stock torque arm works on the moser 12, that a spohn torque arm should also. Bought one from a member and I cant get the damn thing onto the housing, seems like it's 1/8 inch too narrow at the end :confused:
greenmachinedriver
12-15-2007, 11:58 PM
ive got a sphon toque arm with a 12 bolt and it has two sets of holes so that it will fit a 10 and 12 bolt. the other arm i had did not and i had to gind the end a little.
97s10ondubs
12-16-2007, 12:06 AM
Yea this has two sets of holes also, but put it like this if the end with the bolt holes is 6 inches from top to bottom, the width of the housing is 6.1 inches. I cant even get it on there to use either set of bolt holes.
greenmachinedriver
12-16-2007, 09:19 PM
are you saying the torque arm will not slip over the the housing or the bolt holes dont line up? it sounds like it might be bent?
97s10ondubs
12-16-2007, 11:13 PM
Yea I unbolted the piece that bolts to the housing and it is bent slightly, about 1/8-1/4 inch. Found that out earlier, a little upset, but it can be fixed.
