firebirdStud
12-06-2007, 11:14 AM
I have a powdercoated red Spohn adjustable torque arm for my 95 bird. Anyway, I got the crossmember bent for the y-pipe. Turns out I dont need it bent down, so I want to get the straight across peice. I will trade my bent one straight up for your straight one. Must be red powdercoated from Spohn so it matches my setup. I want to know the miles on yours too, and the condition. Mine is flawless, minus a little bit of scraping on the bottom of the bend from hitting a stupid speed bump.
Cody
jakesz28
12-09-2007, 10:09 AM
I have one I could take some pictures if you want me to. Here are the pictures I took of the whole TA. I bought it but used but it won't fit because of the exhaust. I need the bent crossmember.
http://i97.photobucket.com/albums/l211/jakesz28/spohn002.jpg
http://i97.photobucket.com/albums/l211/jakesz28/spohn001.jpg
http://i97.photobucket.com/albums/l211/jakesz28/spohn003.jpg
firebirdStud
12-12-2007, 01:01 PM
wow, this is exactly what I was lookin for. It looks a little scratched up, but other than that it is what I need. The problem is, Im in MN, and the car is now in storage. It is parked about 45 minutes away from me, and its with abunch of other cars. There is no lift or heat or any room to get the car jacked up.. Im stuck until spring. I will not drive it on the salty roads to bring it to work to take it apart, and plus it would just sit broken outside in the elements while I waited for yours to arrive...
So, any chance of just selling it? Otherwise I cant do anything until mid march or even april, depends on when it starts raining here to wash the salt off the roads. I honestly didn't think I could get someone to bite so early, I figured I would start now to find someone hopefully by spring.
Let me know what you are thinking!!!
Cody
jakesz28
12-12-2007, 09:49 PM
Well I will probably sell the TA before then. The cross member will clean up decent. It is scrached by the bolt holes and the dirt around the bushing will wash off. If you decide to pull yours apart before spring let me know. I have someone interested in buying this arm but he would rather have the bent crossmember.
I will be going chromoly rod ended with a solid bushing.
