hi im new w/ a question
camaroLevi
12-03-2007, 07:34 PM
my 2000 3.8 series 2 , has thwrown several codes from the ob2 out p1518 p0443 p0449 from an equus 3030 innova and i have no clue what the exact problem is or not ,...the main p1518 is a- pcm to tac(?) module serial data circuit? ,...the problem happened one day 4 months ago on my way to work the throttle seem to like cut out and it took me forever to get to 60mph and a few days ago(its been in the garage) i took it out and would not go pass 2nd gear it felt like,....please please help me anyone>? im desperate --i love my camaro-- camaroLevi
valter
12-04-2007, 02:48 PM
Double check all fuses. If they are all ok, it seems to be your Electronic Throttle Module needs to be replaced
camaroLevi
12-11-2007, 06:18 PM
i got a chiltons camaro book AND it looks like its a solenoid in the evap canister behid the wheel well , can anyone help me on how to get to that??
smithtim
12-12-2007, 02:22 PM
I didn't look up your codes so I'm not diagnosing here nor am I suggesting that the solenoid is the problem. However, on my 97 the solenoid is actually located on the passenger side on the motor (pretty much tucked under the intake manifold) and is attached by a little black EVAP system hose to some other plastic electrical deals. Maybe they moved it on the 2000?? or if it is the canister itself that is easily accessible inside the wheel well, think rear driver side if I remember correct.
camaroLevi
12-13-2007, 07:12 PM
thanks im sure that helps alot, thanks bro
valter
12-14-2007, 08:00 AM
You should concentrate on your throttle module code. Just disregard your EVAP codes for now, they will not affect how your car runs at all.
camaroLevi
12-14-2007, 06:31 PM
well how much would a throttle module cost approx.?? id rather replace it because this chiltons book is hard to troubleshoot with, and the pix are all blACK and grey
Evolution223
12-21-2007, 04:25 PM
don't get depressed about it, it's just probably one little thing causing all your probelms. Once you find it you'll be glad you bought a camaro, the cars have lots of torque and good looks.
