superduty95
11-30-2007, 03:55 PM
I just got my tranny and clutch out and found out i broke a spring in the hub as well as my pilot bearing just fell out! any thought on if i damaged my crankshaft?
pilot bushingsuperduty95 11-30-2007, 03:55 PM I just got my tranny and clutch out and found out i broke a spring in the hub as well as my pilot bearing just fell out! any thought on if i damaged my crankshaft? wrd1972 11-30-2007, 04:32 PM You will need to clean the carnage out of the hole in the back of the crank and inspect it closely. If the new "BUSHING" will tightly fit in replacement of the trashed roller bearing you should be fine. Do not use another roller bearing if thats what you did actually use. | ||
