LukeZ28
11-28-2007, 11:54 PM
OK I have used tunercat for a while now and was tuning on the dyno. In the middle of writing got the following error;
"Run-time error 8021
Internal error retrieving device control block for the port"
The program froze and I had to shut off the laptop. At this point I tried a read and write and it couldn't communicate. So brought the PCM to GM and they couldn't flash it back to stock. Then found a PCM shop that told me the boot section wasn't retrievable and I would need another pcm. They sold me a reman unit ($175) and loaded a stock flash. Installed the PCM and did a read and then a write so I could start the car. Again the car was on the dyno and about the 3rd tune it gave the error again and locked the PCM. This time it was toward the end of the write so hopefully it got through the boot section. I will have them check this out tomorrow and hopefully not have to buy another PCM.
The battery has good voltage.
Pulled the fan fuse.
Made sure all the doors were shut and no accessories were on.
Turned off wireless, security software, and power saving modes.
Gateway laptop about a year old.
Recently loaded LT1edit for OBD2 programming.
I am using AKM cables USB cable with both OBD1 and OBD2 connectors.
Anyone seen this error?
I am thinking something is trying to access the com port while its writing, but not sure what it would be because tunercat is the only process running in task manager.
