SiDeWaYZz28 11-28-2007, 04:04 PM Hey everybody
who can give me the best deal on
AFR 227
EDELBROCK LT4 INTAKE
JESSAL SHAFT MOUNTS
vendors shoot me Pm with deals
Ray@NitroDaves 11-28-2007, 06:03 PM I would reccomend the Edelbrock Vic-E and an elbow over the LT4....unless you need to keep the "stock" appearance.
http://www.fquick.com/images/vehicles/full/67678534.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=78534)
White Lightning 11-28-2007, 06:17 PM who does the intake conversion on the ''e''?
Eric@Victory Racing 11-28-2007, 08:31 PM We have done the single plane conversions for LT1's.
We are a stocking warehouse dealer for Jesel, and will work you out a package deal tomorrow.
SiDeWaYZz28 11-29-2007, 12:46 AM We have done the single plane conversions for LT1's.
sounds good the afr heads I want are the #1126
Ray@NitroDaves 11-29-2007, 10:52 AM who does the intake conversion on the ''e''?
I had my heads drilled to accept the SBC intake bolt pattern, instead of converting the intake manifold. This way I can switch manifolds if needed and can use any off the shelf SBC unit.
The Engineer 11-29-2007, 04:01 PM We are a stocking warehouse dealer for Jesel, and will work you out a package deal tomorrow.
Which model Jesel shaft rockers will fit on AFR 195, LT4 Street heads without any machining? I understand Jesel makes them, just don't know which model and part number.
WD
Eric@Victory Racing 11-29-2007, 04:31 PM Jesel Sportsman Series
Part Number KSS-336060
$825.00
SiDeWaYZz28 12-04-2007, 12:05 PM to the top
SiDeWaYZz28 12-12-2007, 03:14 PM any other vendors?
SiDeWaYZz28 12-13-2007, 10:37 AM heres the part list
jesel
Part Number KSS-366060
Edelbrock LT4 INTAKE
Part Number EDL-7109
AFR 227's
Part Number 1126
SiDeWaYZz28 12-19-2007, 01:01 PM to the top for today
The Engineer 12-20-2007, 03:35 PM Jesel Sportsman Series
$825.00
Just to double-check the part numbers I called Jesel a few days ago. They told me "only" their Competition Series part number KCS-313121 rockers will work on my AFR LT-4, 195 street heads which were manufactured in 2005 or 2006. (????)
I also called AFR, they “think” (but not completely sure) the Sportsman Series for 23 degree SBC heads (same number you gave me) should work on my AFRs. The price you quoted is very good and I would like to use the Sportsman Series Jesel rockers. However, I first need to be absolutely sure I’m ordering what will work with the AFRs.
Also, I plan to use custom 3/8” push-rods and I know the rocker offset can be an issue with the push-rods rubbing the heads if everything isn’t correct.
Thanks,
WD
Eric@Victory Racing 12-20-2007, 03:45 PM Just spoke with Jesel and the 23 degree kit for the Sportsman Series "should" work. I also got a price on the new AFR LT1/4 Competition kit. They do not have a specific LT1/4 listing in the Sportsman Series.
$825.00
Jesel Competition Series
Part Number KCS-313121
$1249.99
The Engineer 12-20-2007, 04:25 PM Just spoke with Jesel and the 23 degree kit for the Sportsman Series "should" work.
What if I get the Jesel Sportsman shaft-rockers and they're are some issues?
WD
Eric@Victory Racing 12-21-2007, 06:16 AM I am going to call Jesel again today. I don't understand why they can't give me a exact answer on whether they will work or not, and see why they are confident in the competitioin series, but not on the Sportsman.
The Engineer 12-22-2007, 08:07 AM I am going to call Jesel again today. I don't understand why they can't give me a exact answer on whether they will work or not, and see why they are confident in the competitioin series, but not on the Sportsman.
Thanks! I'll be looking forward to hearing back from you. I would like to upgrade to the Jesel shaft rockers and the Sportsman Series would be more than adequate for my application. And, I like the Sportsman price.
WD
SiDeWaYZz28 12-22-2007, 11:43 AM I am going to call Jesel again today. I don't understand why they can't give me a exact answer on whether they will work or not, and see why they are confident in the competitioin series, but not on the Sportsman.
I have the right part # for the jessels that will work with the arf 227 right?
SiDeWaYZz28 12-27-2007, 11:56 AM any new year deals poppin off
SiDeWaYZz28 01-14-2008, 02:49 PM I have the right part # for the jessels that will work with the arf 227 right?
its the right one right?
The Engineer 01-21-2008, 09:11 AM I am going to call Jesel again today. I don't understand why they can't give me a exact answer on whether they will work or not, and see why they are confident in the competitioin series, but not on the Sportsman.
Did we ever get an answer back from Jesel about using their Sportsman Rockers on my AFR 195, LT4 heads (#1031)?
Thanks, WD
Eric@Victory Racing 01-21-2008, 12:31 PM Talked to them and they stated the above listed part number was correct for your cylinder heads.
AFR/23 Degree SBC
