98 t/a roller 12-bolt
red83
11-28-2007, 10:06 AM
lets try it this way. i have it posted on here w/ alot more still on the car with little results. so i figured i would take some of the money off the car and see what happens.
car is located in cartersville ga 30120
98 t/a 1003xx miles on chassis
clean ga titile
original 6-speed car(now has a automatic pedal assembly)
have both console inserts (auto and manual)
moser 12-bolt 4.56 gears full spool 5/8 studs alum cover w. bearing support
aftermarket ws6 hood (not sure on brand)
bmr sfc's
bmr trak-pak torque arm
bmr driveshaft safety loop
qa1 coilovers in front
eibach drag spring
comp engineering rear shocks
racetronix fuel pump
hot wire kit
gray leather interior
comes with no rims or tires. so you will need to supply roller, unless you want the bogart setup that is on the car for an additional 1500.00
the cage in the pic is a wolfe bolt-in. and is not included, but can be for additional$$$
this car is currently running consistent 6.9x in the1/8 and is still together. i just found another car i want and i dont have enough room for all my toys.
all you will need to do is drop a motor and transmission of your choice in and go
if you need more pics. leave a email address
4800.00 obo
no low ballers. please!
onebad636
11-29-2007, 08:50 AM
Pics? how much all together?
red83
12-01-2007, 09:22 AM
email address?
