Madman Manual Steering Rack
Old Nov 26, 2007 | 06:52 PM
nonosvt's Avatar
Its this the only one out there for our car? I am just wanting to see if there are any other types of steering racks. thanks John
Old Nov 26, 2007 | 08:12 PM
nonosvt's Avatar
anyone?
Old Nov 26, 2007 | 09:09 PM
greenmachinedriver's Avatar
this should probably be in the suspension section. madman is the only one i know of. one of my freinds did the manual rack conversion on his car with madman parts and it was a nightmare. he put in the k-member with the pinto rack mounts and the pinto rack and steering shaft kit made for an f-body from madman. the rack bolted to the k member just fine but the steering shaft would have to run through the headder and motor mount to even come close to working. we ended up having to cut the mounts off the k-member an moving them over a few inches to get the steering shaft to turn without binding. we also had to cut a section out ofthe drivers side tie rod and weld it back together to compensate for shifting the rack over.
this i just a cautionary tale. if you decide to go this route i would recomend getting the k-member with the stock mounts and the stock style manual rack. it is more expensive but definately worth the extra cost.
Old Dec 2, 2007 | 11:35 PM
sn8ke eatr's Avatar
i dont theres such thing as a stock manual steering setup on an f-body?
Old Dec 3, 2007 | 10:00 PM
there are two styles that i know of the pinto style mount and the stock style mount sorry if i was unclear. as far as i know there was never a fourth gen without ps from the factory. lol
thease are the two styles i was thinking of...
http://www.thunderracing.com/catalog...vid=4&pcid=255
Old Dec 4, 2007 | 12:17 PM
n2ceptor's Avatar
Correct, only PS...... Manual is aftermarket.......
Old Dec 5, 2007 | 10:48 PM
kylersaulsbury's Avatar
or just take your p/s pump out and use the stock rack and pinion w/o assistance from the pump. right?
Old Dec 5, 2007 | 11:55 PM
n2ceptor's Avatar
It wont work.......Be like trying to turn a tank.... Very unsafe.....
Old Dec 6, 2007 | 09:54 PM
It was just a thought.... But yeah i figured it wouldn't be fun, but i couldn't see it being too hard to turn w/ skinnies. Either way I see how it would be unsafe.
Fastbird93
Apr 9, 2016 07:01 PM
colts0455
Jul 7, 2015 07:19 PM
Scorch1
Jun 30, 2015 11:24 PM
Injuneer
May 15, 2015 08:45 AM
