Garcia95
11-26-2007, 01:34 PM
does any one know what are the specs of the camshaft and the valve terain of a 95 3.4 camaro
thanks
frank
thanks
frank
original cam specs of a 95 camaroGarcia95 11-26-2007, 01:34 PM does any one know what are the specs of the camshaft and the valve terain of a 95 3.4 camaro thanks frank blindxeyed 11-26-2007, 07:01 PM Bore & Stroke: 3.62" x 3.31" Compression Ratio: 9.0:1 Engine Block: Cast Iron Camshaft: Hydraulic Flat Tappet Design Valve Lift (Intake/Exhaust): .427" / .454" Duration (Intake/Exhaust): 204 / 216 at .050" Lift Cylinder Heads: Cast Iron Valve Diameter (Intake/Exhaust): 1.72" / 1.60" Hope this helps. May be more info that you need, but hey.. Garcia95 11-28-2007, 02:07 PM thanks man FunkZ 11-28-2007, 08:07 PM Those are NOT the stock cam specs, those are the numbers on the GMPP cam and the Crane 260H. Here ya go. http://www.fullthrottlev6.com/forums/showthread.php?t=32901 blindxeyed 11-28-2007, 08:17 PM Those are NOT the stock cam specs, those are the numbers on the GMPP cam and the Crane 260H. Here ya go. http://www.fullthrottlev6.com/forums/showthread.php?t=32901 Alas, someone has lied to me! Thanks Funk, would have hated for that guy to get the wrong info. Garcia95 11-30-2007, 01:51 AM its cool man its a common mistake FunkZ 11-30-2007, 07:18 PM Just realized you asked for valvetrain as well. The stock rockers are 1.5 ratio, not sure on the spring rates though. | ||
