INTMD8
11-23-2007, 07:25 PM
I've decided to build another car so my 96 is up for sale. I've owned the car since Dec of 98 with 36k miles. Odometer shows 73k miles now.
It's red with graphite leather, power, and t-tops. Here's what it comes with and original cost of said items-
Wet sanded/buffed exterior paint (no orange peel) 300
Engine compartment,undercarriage,rocker panels and wheelhousings stripped to bare metal, etching primer, primer filler and DuPont base/clear. Materials- 650
(and many weeks of labor)
Wolfe 6pt bolt in roll bar powdercoated black- 575
dynamat sound insulation on floorpan- 125
5pt cam lock harness- 140
All hard brake lines stainless steel, and stainless brake hoses- 525
Fuel system- walbro intank pump, aluminum secondary fuel cell with walbro inline pump. 2 -6 feeds 2 -4 returns, Earls pro-lite 350 black braided hose, endura hose ends. I used the seperate fuel system for the staged injection but it could be used for a stand-alone nitrous fuel system as well.- 1000
Rearend- Currie 9in with moser aluminum center section, detroit true-trac, 3.25 gear, 31 spline axles, 3-channel ABS. Housing powdercoated black 3250
Suspension- BMR K-member (LT1 or LS1, whichever you prefer), 1LE upper/lower and rear control arms. Bilstien shocks/eibach springs. Spohn torque arm, spohn adj panhard bar. Swaybars, brackets, spindles and many other parts were powdercoated black- 1800
Gauges- fuel pressure and boost gauges integrated into dashboard. Switch under dash toggles between primary and secondary fuel system level and pressure. Autometer shift light - 300
Fire suppression system with underhood and passenger compartment nozzles-
700
Electrical- Optima red top, aluminum holdown, master shutoff activated by trunk key, 0 gauge cables- 375
Baer track kit front brakes- 1025
17x9 and 17x11 5 spoke SS wheels with Goodyear GSD3 tires- 1500
Comes with cooling system, A/C system, PS system as well.
Parts Total- $12,265
Price for the car is $8,500 with all the parts.
Pictures of the car are here- http://www.ls1speed.com/intmd8.cfm
Everything on the car is show quality, just add your engine/trans.
Again, to clarify this is for the rolling chassis. No engine/trans included.
700
