Code P0001 and P0003- Is this a bad fuel pump?
Matts97camaro
11-23-2007, 09:07 AM
My car just died going down the road. I scanned the OBDII I got these codes. It will not start for anything, just turns over. I think its the fuel pump. What do you all think? Car is a 1997 Camaro V6. Broke down driving to my inlaws house on Thanksgiving day, what a day.
These are the DTC generic definitions that my scanner pulled from the OBDII
P0001- Fuel volume control circuit open
P0003- Fuel volume regulator control circuit low
Injuneer
11-23-2007, 11:28 AM
Wrong forum... "LT1/LT4 Engine Tech" is for the 93-97 V8 engine. I'll move your post to the V6 forum. You also might want to check your codes.... none of my sources list anything under P0101 for the V6 engines.
Matts97camaro
11-23-2007, 09:38 PM
All
I found the problem. I don't know why I got a fuel code. It was a blown fuse for the ignition. I replaced the fuse and the car ran for about 5 min then blew the fuse again. I scanned the computer and found a P0300 code- misfire. I found the ICM to be bad. I took it to the parts store to test, it was bad along with 1 coil. I replaced the ICM and coil and fuse for 160. Installed everything myself and she is running great. :D Glad it was not the fuel pump...
