93camarochrisz28
11-22-2007, 05:14 PM
like said in title is there a way to do that thanks for the help
is there a way to by pass the knock sensor on a 9393camarochrisz28 11-22-2007, 05:14 PM like said in title is there a way to do that thanks for the help Injuneer 11-23-2007, 02:33 PM There's a way to put a resistor in the circuit, either to 'desensitize' it, or to eliminate it. The desensitization circuit is a bit more involved than simply putting a resistor in series with the sensor. But to eliminate the sensor, simply bypass the sensor by connecting the single harness wire to one end of a 4,500 ohm resistor, and ground the other end of the resistor. Operate at your own risk..... :) 93camarochrisz28 11-25-2007, 09:56 PM i hate to askthis of you is there any way yu could make a diagram that i can see to understand a little better Injuneer 11-26-2007, 12:12 PM Which one... the desensitize ciruit, or replacing the sensor with a resistor? I don't have the desen circuit, but you can find it with a "search". To replace the sensor with a resistor, you pull the single dark blue wire off the knock sensor (passenger side, bottom of the block, just behind the motor mount). Attach the dark blue wire to one end of the 4,500 ohm resistor, and wire the other end of the resistor to a ground. You just leave the knock sensor in the block, with no wire attached to it. 93camarochrisz28 11-26-2007, 04:05 PM cool thank you so much i am gonna search for it right now | ||
