1992 Camaro RS 383 Super Ram
Old Nov 18, 2007 | 01:26 PM
max_maro92's Avatar
I am the second owner of this 1992 Chevrolet Camaro RS, and I have owned the car since 1994. Purchased in bone stock condition the car was modified over the years to the level it is currently in. During it's last transformation I unfortunatly began to lose interest in the project all together. Now after being stored indoors for 2 years I have decided to let go of the car. I have invested over 25,000.00 in the car, the engine has under 1000 miles on it. I would love to keep the car stored for another 2 years but I simply must let go of this project. The car has a custom built 383ci (6.5 liter) engine backed by a custom built racing automatic transmission. The entire suspension and steering system has been replaced and upgraded including the front subframe. The brakes, cooling and interior have also been modified and upgraded. The car is factory purple haze metallic in color with a black interior and is equipped with a T-top roof. The car in general is in good condition, the paint has started to fade in certain areas and the front bumper has been replaced but not painted. There are some minor door dings and the passenger side fender is also slightly dented. The car has AC, A/T, P/S, PW, PL, PT, and anti-theft. The car has a clean title and is not a salvage vehicle.
Major Modifications Include:
Balanced and Blueprinted 4 bolt main 383ci long block. Scat crankshaft, eagle forged connecting rods, JE flat top forged pistons, high volume blue printed oil pump. ARP studs used throughout to secure main caps, oil pump, and cylinder heads. Canton racing 7QT oil pan fitted with crank scraper and windage tray.
Air Flow Research 195cc Aluminum cylinder heads. CNC port matched and serviced by Gromm Racing Heads.
TPIS ZZ-9 hydraulic roller camshaft / Comp Cams high rev series lifters / manley chromoly pushrods / Crane roller rockers.
Accel / Lingenfelter Super Ram Plenum and Runners with custom port matched Edelbrock lower manifold. Entire intake manifold has been fully hand ported. BBK 58mm twin blade Throttle Body.
MSD Digital 6 plus ignition with crane PS-91 coil and taylor spiro-pro wires. NGK spark plugs.
SLP 1-3/4 inch shorty style hedders with smog tubes, modified SLP Y-pipe and custom built 3 inch exhaust with a single 3 inch magnaflow muffler.
Custom built 700-R4 automatic transmission with upgraded band, clutches, servo, customized valve body, precision industries 3500rpm stall racing torque converter (with lockup feature.) B&M stacked plate transmission cooler with aeroquip lines and fittings.
Custom built 3" seamless steel driveshaft with 1 ton universal joints. Built by South Bay Driveline.
Auburn positraction rear differential with 3.42:1 ring and pinion. Amsoil synthetic gear oil used.
Griffin aluminum racing radiator dual 1-1/2" rows. Fitted with flex-a-lite dual 12 inch computer controlled fans.
Pro-Fab custom tubular front subframe powdercoated black with reinforcement gussets added. Spohn "wonderbar" steering box reinforcement bar.
Pro-Fab Tubular front control arms with delrin bushings.
Custom Bel-tech 2 inch drop spindles modified and fitted with 12 inch rotors and dual piston PBR calipers (same brake system that is equipped on the 2000 camaro SS.)
Tubular adjustable rear control arms and adjustable panhard bar with heim joints. Tubular torque arm with adjustable pinion angle and heim joints. Eibach rear coil springs.
Harwood fiberglass "Bolt On" cowl induction hood. Hinges and latch are fully functional.
Custom fuel delivery system with high output Walbro fuel pump and aeromotive pressure regulator. Aeroquip stainless steel lines and fittings used throughout.
Monaco RS racing seats (matching driver and passenger side) with slider and recline adjustability
Autometer pro-comp silver series gauges and 5” monster tachometer. Guages include oil temp, trans temp, air/fuel, fuel pressure, vac/boost.
Hella H4 conversion headlamps with high light output H4 bulbs.
The purchase of the car also includes a set of Edelbrock weld-in subframe connectors, Edelbrock strut tower brace, a custom fitted all weather car cover (300.00 retail value) Owner's manual, receipts dating back to 1994, and extra T-top bag. The car is currently located in California and registered as a PNO (planned non-operation) all matters concerning registration of the vehicle after purchase shall be the responsibility of the buyer. The yearly fees for PNO registration have been paid so there should be no back fees associated with this car. Please note that due to the Level of modification to the car it is being sold as a custom racing vehicle. While the parts used in the transformation of the vehicle carry C.A.R.B. exemption numbers I make no guarantees as the the ability of this car to pass a state emissions test. Again in it's current condition this car is for off-highway racing purposes only. Please feel free to email or call me with questions or if you are interested in the car. I am willing to work with an out of state buyer concerning shipment of the vehicle. Asking price is reduced to 6800.00. I can be reached at (408)221-5202 or emailed at max_maro92@yahoo.com
Old Nov 20, 2007 | 04:18 PM
max_maro92's Avatar
Bump*
Old Nov 30, 2007 | 11:48 AM
max_maro92's Avatar
*BUMP
Still For Sale!
Old Feb 1, 2008 | 01:13 PM
max_maro92's Avatar
*TTT
Car is still available
Old Feb 9, 2009 | 02:10 PM
max_maro92's Avatar
Back from the dead.
Actually back home, car didn't sell before I left. Reduced asking price to 6800.00
Old Mar 7, 2009 | 12:39 AM
max_maro92's Avatar
Bump
Old Mar 31, 2009 | 10:41 AM
max_maro92's Avatar
BUMP
New plugs, fresh fuel and a wash over the weekend!
Old Apr 1, 2009 | 04:24 PM
96' Formula WS6's Avatar
Bump fpr a sick car man. I dont know if i missed it in the discription but have you had the car dyno'd or have any track numbers on it.
Old Apr 11, 2009 | 01:35 PM
max_maro92's Avatar
No, unfortunately I do not have any dyno or track numbers on it...the project got put on indefinite hold before any of that took place.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Kato
Jan 26, 2015 09:21 PM
NewsBot
Jan 8, 2015 11:29 PM
Collector Car
Dec 17, 2014 01:12 PM
