why does n20 like a larger lobe separation angle?
Old Dec 6, 2002 | 07:06 PM
lt4 fd's Avatar
Old Dec 7, 2002 | 02:32 AM
MBonZ28's Avatar
nitrous likes a lot of cylinder pressure, lots of seperation gives you that
Old Dec 7, 2002 | 07:09 AM
lt4 fd's Avatar
In a force induction motor I know if there is too much overlap the pressure can escape out the exhaust valve, is it the same with n2o? Only other way I see pressure loss is from the exhaust valve opening too early. Are either of those the case?
Old Dec 16, 2002 | 11:38 PM
agent712's Avatar
More cylinder pressure.... does that mean that nitrous motors like more compression?
-Nick
94 Z28, 6 speed
Old Dec 17, 2002 | 03:45 PM
ZDriver96's Avatar
yes
Old Dec 17, 2002 | 04:17 PM
agent712's Avatar
Really? So that means my 12.5:1 compression on the stroker I'm building would be better than 10.5:1? Could someone explain this to me, I dont' really understand why...
-Nick
94 Z28, 6 Speed
Old Dec 17, 2002 | 09:41 PM
94droptopz's Avatar
from all the motors ive built in the past id say thats wrong. nitrous is not a forced induction but it does work better with a lower compression motor. if you slam i 150 shot into a 12.5:1 motor that is not very well equiped...... im just glad its not mine
Old Dec 17, 2002 | 11:58 PM
CustomN2O's Avatar
Compression will help any motor. It has nothing to do with how much nitrous you can run in the motor. If you are going to run lots of nitrous with high compression, you just need to make sure you are using the proper fuel, and the timing is correct. The more compression, to an extent, the more hp your motor will make. Lobe seperation angles dont have to be wide for a nitrous application, but that is the latest fad. What they are trying to do is open the exhaust valve a little later, to allow more burn. When you start running high nitrous levels, you will learn that over lap is actually a good thing, and can help you in more then 1 way. It doesnt hurt to blow a little nitrous out the exhaust on overlap, it helps cool off the piston, and clean out hte combustion chamber of any unburnt fuel, or exhaust. The valve timing and events are really what you need to look at when choosing a cam. More lobe seperation isnt going to give you it all the time.
Old Dec 18, 2002 | 06:02 AM
94droptopz's Avatar
i just had the figures the other day about compression. you lose 4% per cc. is it really worth it? you run a 150 shot on a 12.5:1 motor thats already making serious heat,and now your just adding to the burn. you gonna melt something. espicially on a stock motor which i think has composit pistons. go with forged pistons and a little lower compression, its a lot safer and a lot easier on the motor. thats just my opinion
Old Dec 18, 2002 | 07:59 AM
CustomN2O's Avatar
Heat is HP. I didnt think the guy was talking about a stock motor, anyways, the compression "heat" isnt what melts parts. A severely lean nitrous injection, along with detonation, is what makes a "blow torch" effect, and cuts right through the heads or pistons. Keep the detonation under control, and the nitrous tune right, and the compression will only help you out.
Old Dec 18, 2002 | 08:48 AM
agent712's Avatar
So you're saying that my setup will be fine assuming we do a special tune for running nitrous, and use the right grade fuel? I plan to run 106 octane unleaded anyways.... so that shouldn't be an issue.
BTW. The cam I'm getting has just under 112 lsa.
-Nick
Old Dec 18, 2002 | 10:01 AM
red's Avatar
red
-Nick
Like mentioned earlier you should match your ignition advance to the amount of N2O you are running to eliminate detonation. Also it is a good idea to tune with a wide band O2 sensor or EGT's to make sure you are not getting too lean.
Where have you found 106 octane unleaded?
Old Dec 18, 2002 | 09:09 PM
agent712's Avatar
Oh, sorry, I guess the highest I've found is 100 and 104. Here are the links...
76 Racing fuels
Sunoco racing fuels
-Nick
Old Dec 18, 2002 | 09:39 PM
red's Avatar
red
76 Racing fuels
Sunoco racing fuels
-Nick
Thanks Agent. The highest I have ever seen is 100. Looks like I will be trying out the Sunoco when running the spray.
LT14LIFE
Nov 15, 2015 06:22 PM
95chwagon
Oct 16, 2015 12:24 PM
Sep 17, 2015 11:53 AM
Fatdog2
Sep 16, 2015 11:04 PM
Aug 7, 2015 01:26 PM
