cmzfly93
11-15-2007, 03:54 AM
hello
I have a 1993 Camaro lt1 procharged new 355 with stock ported heads 224/236 114 cam pacesetter headers, ported intake, ported tbody 42 lbs injectors. I have a pcm tune it right now with p1sc procharger 2 bar tune 12 psi pulley only see about 9.5 psi I have about 1000 miles on motor. Running pretty could first 950 miles about 126mph in quater on street tires about 485 rwhp i think. MY questin is this I have an intake oil leak and wp drive leak i think. New opti spark like 5000 miles ago accel 9000 plug wires msd coil and tr6 nkg spark plugs. I have driving it and went to WOT and the tach started jumping when I hit about 5000 rpm it was bouncing all over like something was wrong went home let it sit for about a week started it up after wiggling plug wires and opti connections and coil connnection. Hoooked up datamaster timing was at 26 to 26 degrees with tune now i am only at 22 to 23 degrees no codes in computer. I am down at 50 hp is that just frome the timing and if so why did it move. could the opti be broke and throw no codes just change timing.
thanks
ryan:(
thanks
ryan:(
