what rims are these?
reamo04
11-14-2007, 07:52 PM
his fron'ts do not look like they stick out like a prostar
http://i5.tinypic.com/6xuuulz.jpg
http://i4.tinypic.com/6yufifp.jpg
interested in knowing, caue i'd like to pick a set up, cause i don't want my fronts to stick out
Injuneer
11-15-2007, 11:00 AM
Looks like they may be the Bogarts.
http://www.injuneer.com/images/photos/GeorgeB/DCP03828a.jpg
http://www.injuneer.com/images/photos/GeorgeB/DCP03863a.jpg
Z-RATED94
11-15-2007, 12:15 PM
I think Fred is right. I purchased the welded RTs for that reason. The fronts don't stick out, and the backs tuck in nicely. If you have LS1 front brakes though, it moves the wheel out slightly. I don't and do not plan on going with those brakes.
Plus, with these wheels there is no grinding, spacers, using a hammer, etc. I did trim the bump stops to clear the tire though, it rubs slightly when the car is jacked up. But other wheels are worse in this respect. Just be ready to lay out some extra money for these benefits.
reamo04
11-15-2007, 01:38 PM
dang, so those are out of the question since the car will see street duty, and bogarts do not like that do they?
reamo04
11-15-2007, 01:44 PM
wait, look at the front rims on the car i posted, where the bogarts on the "star" part, slant inwards, the ones i posted stay straight, so i believe they are something else
reamo04
11-15-2007, 01:49 PM
well guys, after some looking around, these look a little closer to what i posted
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D521%2D5461PS&N=700+4294923107+4294923106+4294923105+115&autoview=sku
would 1.75" backspace on a 4" rim work, or would those stick out?
Injuneer
11-15-2007, 06:41 PM
The Bogarts are the "SS" model and completely "flat" on the center section (spokes). The wheels you linked on Summit are the old Weld Pro-Star XL wheels. They have a curved surface on the spokes.
reamo04
11-15-2007, 06:47 PM
alright, thanks injuneer. Since I dont want bogarts since the car will bes treet driven, would those "Summit Star" rims work for the 4" rim with a 1.75" backspacing?
Injuneer
11-15-2007, 11:56 PM
I have a 3.5" wheel with 1.75" BS. With the 5/16" spacer, it "sticks out". If you had a 4" wide wheel with a 1.75" BS, and no spacer, your wheel would stick out 0.18" more than mine.
Z-RATED94
11-16-2007, 11:20 AM
Should you drive them on the street? No. But you know how it goes, do as I say, not as I do! ;) Very carefully though (turns), and this is not my DD. So far 1k and no problems.
JGKadell
11-18-2007, 04:04 PM
Those are Bogart's but not the SS. It is the DOS, Drag on Star
