Style
11-12-2007, 11:54 AM
Is the refresh/sample rate on AutoTap limited by software or OBD II communication? If it is software, is there anyway to increase the sample rate?
AutoTap Sample RateStyle 11-12-2007, 11:54 AM Is the refresh/sample rate on AutoTap limited by software or OBD II communication? If it is software, is there anyway to increase the sample rate? Style 11-15-2007, 12:23 AM Alright being that no one knew the answer, here are some facts I found out in a recent e-mail: -Most GM and Ford vehicles = 30-35 updates per second -The "export to comma delimited" turns the log file into a .csv to use in a spreadsheet. The .csv file will also provide a timestamp for each parameter update -The VIN is automatically read on GM, but for Ford or imports, the VIN has to manually be entered. -V 3.1 improvements over v 3.0 are better error handling capabilities The one thing he did not answer is if AutoTap reads the datastream under WOT. It seems that I couldn't the 4 times I tried. Also, I am still not sure what is the limiting factor in sampling. If I have almost every parameter monitoring, is the sample rate slow because of the software or hardware? | ||
