roller71
11-12-2007, 01:35 AM
How Do I Know If ECU Is Gone Bad
How Do I Knowroller71 11-12-2007, 01:35 AM How Do I Know If ECU Is Gone Bad steve9899 11-12-2007, 01:48 AM How Do I Know If ECU Is Gone Bad If you catch it smoking in the boys room. Or if you install it in a known good car, with a known good program, and it doesn't work. roller71 11-12-2007, 02:07 AM If you catch it smoking in the boys room. Or if you install it in a known good car, with a known good program, and it doesn't work.dude that suxs, if i had a good car i wouldnt need a bad 1, or is it just that hard to tell VinceTrifecta 11-12-2007, 07:14 PM What's the car doing? roller71 11-13-2007, 06:12 AM What's the car doing?its not firing nothing going to ecm or coming out VinceTrifecta 11-13-2007, 11:20 AM Hmmm. That could be caused by a number of issues. Does the check engine light come on when you turn the key on? roller71 11-18-2007, 04:46 PM Hmmm. That could be caused by a number of issues. Does the check engine light come on when you turn the key on?yes, I ordered a obd1 scanner yesterday gonna check codes and ill let you know what it tells me lovesafron 11-20-2007, 08:19 AM Dude to get this type of answer you are raising query is good i also have same problem and get resolved. roller71 11-21-2007, 07:59 AM Dude to get this type of answer you are raising query is good i also have same problem and get resolved. COMPUTER WAS BAD WOULD EVEN P/U ON SCANNER,CHANGED COMPUTER PICKS UP ON SCANBUT STILL DOESNT FIRE GONNA CHANGE OPTI TODAY roller71 11-21-2007, 08:02 AM Hmmm. That could be caused by a number of issues. Does the check engine light come on when you turn the key on?ALWYS ON AND AND GAUGE NEEDLES DONT MOVE WHEN YOU TURN THE KEY ON IS THAT NORMAL FOR THIS MODEL OR SHOULD THE GO OVER AND BACK | ||
