Waste gate on a Centrifugal Supercharger with adjustible boost...
Old Nov 10, 2007 | 06:52 PM
chriswtx's Avatar
What do you guys think of this???Centrifugal Supercharger with a Wastegate for controlling boost, then you can pulley for 18-20psi of boost and have a boost controller so on the street and putting around you could run say 14psi max but still have the faster ramp boost curve of the smaller pulley and 20psi is just a push of a button away......
I know this has been discussed before and most said it wont work...Well here's one on a working car...
http://www.musclemustangfastfords.co...all/index.html
gotta love different boost settings at a push of a button...
Old Nov 15, 2007 | 11:10 AM
Violat0rX's Avatar
that link doesn't work, can you fix it?
I want to see how it's done. Thanx
Old Nov 15, 2007 | 11:24 AM
chriswtx's Avatar
try this...
Old Nov 15, 2007 | 11:37 AM
Ultra_Dog's Avatar
If it works that would be cool. I'd also like to see a clutched pulley that completely stops the supercharger from spinning when unused. I drove around the other day with my belt off and the car was super smooth and significantly quieter (whine free).
There are just some days that I really get tired of the constant whining....
Old Nov 15, 2007 | 11:39 AM
LittleRedZ's Avatar
i felt the same way when i had my D1
Old Nov 16, 2007 | 01:34 PM
JWS6's Avatar
does the waste gate operate when in vacuum?
Old Nov 16, 2007 | 02:33 PM
LittleRedZ's Avatar
you still going to need different tunes for different boost.
Old Nov 16, 2007 | 03:10 PM
RealQuick's Avatar
In vacuum, the wastegate is closed. Once it sees boost (based on the boost reference line from wastegate to the intake manifold, it will start to open and bleed off. When boost reference = spring pressure in the gate, the gate will open.
Old Nov 16, 2007 | 06:55 PM
blown94's Avatar
Check out a srt-6 crossfire. It has a roots style supercharger with a clutch on it. I dont know how much they boost, but its been done. I couldnt believe it when I saw it. I cant imagine it holds anymore than 6 psi.
Old Nov 16, 2007 | 10:58 PM
Kevin Blown 95 TA's Avatar
How would air get thru a roots if it wasn't turning. Wouldn't it need a bypass tract to the other side of the supercharger?
Old Nov 18, 2007 | 02:06 PM
z96's Avatar
z96
Guys check out the bmw 7 series called a B7 it has a clutch on the front of the supercharger. The super charger is huge looke like a vortec.
Old Nov 18, 2007 | 02:42 PM
gota406's Avatar
It is not a positive seal between the rotors. When the car is running, you can sometimes even see the pulley turning from the vacuum. You'll see this happen at the races from time to time, belt breaks/lose race/still drive home.
11.6 PSI of boost, no Mad Max clutch here.
14.5 PSI and no Mad Max clutch here either.
Boost levels and engineering data is posted from manufacturers websites as well as common magazine websites.
Both cars are interesting none-the-less.
Old Nov 18, 2007 | 02:45 PM
I can see a clutch on a centrifugal, but someone has to show me how it would work on a roots without some kind of a bypass.
Also, for programming, I have a smart spark which can hold two ignition maps and one of them can be switched at the same time as the clutch or whatever would be used for bleeding off boost, so I could do it that way. For fuel, I'm stuck with one map if I stay with the stock PCM. I would much rather go aftermarket and have a wideband with boost referenced fuel.
Old Nov 18, 2007 | 02:48 PM
Originally Posted by gota406
It is not a positive seal between the rotors. When the car is running, you can sometimes even see the pulley turning from the vacuum. You'll see this happen at the races from time to time, belt breaks/lose race/still drive home..
I thought the clearances were a lot tighter than that. Don't some of them even have teflon seals on the rotors?
Old Nov 18, 2007 | 02:59 PM
RealQuick's Avatar
The charge gets pushed around the outside of the rotors (between the rotors and the case)... not between the rotors.
