97formula1234
11-06-2007, 12:58 PM
My scanner port is not working. I want to run new wires from the computer to it. I need help lol
Pleas someone tell me what wire go from the computer to the port and in what spot they go.
I tried looking at several diagrams but just keep getting confused!:mad:
Thank you!
Green96Z
11-06-2007, 04:18 PM
You mean the ALDL port? I can look it up for you, but I'm at work. I have the factory manuals, so if someone doesn't help you until then I'll check.
97formula1234
11-06-2007, 04:21 PM
You would be a life saver! i have been tring to get this answer for over a month!
97formula1234
11-08-2007, 07:50 AM
Did you give up Green?;)
I really wanted to get this done by this weekend so i could put her on a dyno and check my tune, anyone that know are can find out id really appreciate your help.
Injuneer
11-09-2007, 04:24 PM
My scanner port is not working.......
Did you check the fuse for the cigarette lighter? That's where the ALDL connector picks up 12V power.
97formula1234
11-09-2007, 04:54 PM
Tnx for the sugestion, but think i got my wires screwed up when i ran them to the ALDL ODBII port.
shoebox
11-09-2007, 06:12 PM
1996 DLC (http://shbox.com/1/1996_ec_02_DLC.jpg)
2 grounds
1 power
3 that go to the PCM
97formula1234
11-10-2007, 01:03 PM
2 grounds
1 power
how did you find that shoebox? i have been looking for days!
Where do u live, i wana be ur neighbor!
97formula1234
11-10-2007, 08:35 PM
every thing is working now, i has the purple wire routed wrong :mad:
Tnx allot to all that helped!
Oh and BTW on alot of scamtics it says the purple wire (serial dataII) is only used in 96 cars, welp mine is a 97 and needed it. So i dont know if that mean made in 96 or if its wrong
shoebox
11-10-2007, 11:58 PM
...all you need is a factory service manual... :)
