20x10's fit in rear with no mods?
dbacs
11-05-2007, 09:02 PM
Will 20"x10" wheels fit on the rear of a 99 camaro without having to cut fenders or do anything to the car?
Injuneer
11-06-2007, 12:35 PM
The wheel requires the correct offset, and the correct size tire on it. Typically, the tires available for 20" wheels will be larger in diameter than the cars stock tires. A 285/25-20 would be the same diameter as a stock Z-rated tire though. As long as you control the outside diameter within reason it should not be a problem. If the car has been lowered, it may become an issue. A 275/30-20 would be about an inch larger than stock.
dbacs
11-06-2007, 08:12 PM
How do these specs look?...
20x10.0 5x120 +45 Offset
275/30/20
