qudlaty
11-01-2007, 07:06 PM
I've put 17 x 11 with 315 on my car, and the seller gave me some chrome lug nuts. When I put it on it didn't seem tight enough so I tried to tighten it a little more and than took it for a ride and when i came back i wanted to take the wheel off and see if there is any scratches on the tire which would show me that it's rubbing against something. when i tried to take the wheel off i broke one of the pins.
PLEASE tell me it's easy to replace that pin.
How to do it?
__________________
dangalla
11-01-2007, 07:10 PM
what is this pin you speak of?
if i am translating correctly you mean wheel stud. right?
front or rear
qudlaty
11-01-2007, 09:59 PM
yes stud.
It's done. Wasn't that hard. If only someone told me to release the brake before trying to take the discs of.
n2ceptor
11-02-2007, 12:18 AM
You should be using a "bulge nut".... Regular nuts will go in to far and damage the wheel....
Bulge nut..
http://www.dormanproducts.com/images/items/hwrap1/2097871.jpg
Regular nut....
http://www.dormanproducts.com/images/items/hwrap1/2097867.jpg
See the "taper" end difference.....:)
shock6906
11-02-2007, 08:46 AM
It's not hard to replace a stud. Just go get a new one from Auto Zone or something, knock the old one out with a hammer (you might need a rod to push it through the hub) and then hammer the new one in from the back side of the hub. The studs are not even two dollars each.
