PAC Beehive Springs GP?
Shon Herron
10-29-2007, 09:12 AM
Anyone interested in having another GP for these springs?
PAC 1218s $165 shipped
PAC 1518s $235 shipped
Shipped pricing is to the lower 48 states.
mdenz3
10-29-2007, 07:56 PM
I'm interested, but my wallet's not. :(
Alex99
10-30-2007, 08:54 AM
I'm also in for a set of 1518s.
Shon Herron
10-30-2007, 08:59 AM
This is a go, I will set up the website for the pricing above and post up the links, probably later tonight.
Yeahdoug
10-30-2007, 09:26 AM
Shon if you want you can sign up as a wholesaler on our website. I've taken down 10 set pricing on the website to the general public.
WS6NIGHTMARE
10-30-2007, 03:27 PM
Difference between the two?
dangalla
10-30-2007, 03:42 PM
1218 is good for .600 lift
1518 is good for .650
WS6NIGHTMARE
10-30-2007, 03:44 PM
Cool, the 1218's will work for me. I can get in on it next week.
Shon Herron
10-31-2007, 10:29 AM
I noticed.
BTW-due to family obligations last night and tonight, it will be another couple of days before it is up on the site, sorry.
The Engineer
11-06-2007, 10:09 AM
First, I'm getting ready to install the set of PAC-1518s springs (heads on) I bought from Shon Herron a few weeks back. So, yesterday I stopped the local performance machine shop to check on some shims (if I need them) to achieve the correct installed height (1.800").
I got into a discussion (possibly an argument) about the specs on the PAC-1518s (w/ the PAC spec sheet I had) versus the Comp 918s and the Comp spec sheet the shop had. The shop’s position was that the Comp 918s and PAC-1518s are the exact same spring based on their Comp spec sheet. Whereas, it was my understanding the PAC-1518s are an upgrade over the 918s and are rated at .650” lift, w/ 130 lbs closed seat pressure.
Additionally, my understanding was (based on what I had read) the PAC-1215s and the Comp 918s were the same spring, and not the 1518s.
So, what’s the bottom line (1518s-v-918s)?
WD
Shon Herron
11-06-2007, 10:22 AM
WD
PAC 1218's are the original 918s that Comp sold until finding another vendor. And they are processed for .600 lift.
the 1518s are an upgrade due to the .650 lift and the processing of the material to make it stronger.
Does this help?
The Engineer
11-06-2007, 10:49 AM
Does this help?
I thought I was correct about the PAC-1518s being an upgrade spring over the 918s! I just need to "stay away" from the local machine shop and not get in any more arguments with them. Also, they hadn't even heard of PAC springs, which says a lot about them.
Also, I ordered me one of the beehive spring mic's (small top, 1.50" to 2.10") so I can check the installed height on each valve and make sure I have everything perfect on the spring swap!
Thanks again Shon for the great price on the PAC-1518s!
WD
Yeahdoug
11-06-2007, 10:52 AM
There's still a lot of people who don't know about us. We've been behind the scenes for 40+ years. It's funny to see peoples reaction when they find out they've been running our springs for 10+ years.
PAC-1218 and the 918 were the same spring. A 915 is a PAC-1215
The load specs for the 1518 and 918 are the same. Just you can safely run .650" lift on the 1518s since they are nitrided. A 918 was 318lbs at 1.200". A 1518 is still 318lbs at 1.200, but you can run it down to 1.150" where it's 337 lbs.
The real upgrade in the 1518 is its nitriding, which gives it much better load loss and fatigue life. It should last the life of your engine.
The Engineer
11-06-2007, 12:14 PM
Thanks for all the info on the PAC-1518s! I knew I had made the correct spring choice (w/ PAC-1518s) from what I had read, but then got into the discussion with the people at the machine shop (they beat me up on the spring issue). Then I started having second thoughts about being right.
I'm really looking forward to getting the 1518s installed (currently have the 918s). Additionally, I've ordered some beehive titanium retainers w/ 10 degree locks which will be an additional upgrade in the valve-train.
Also, I have the Comp XFI-292 cam w/ 1.6 RRs, so my lift at the valve is in the 590s. The car is used for bracket racing (almost every weekend in the summer) so it sees a lot of track time and high RPM runs.
WD
http://shutter03.pictures.aol.com/data/pictures/11/004/1F/FF/91/78/TVvO8XyPUygvgYoPj6F8FlZny8lGOplE0300.jpg
NemesisLT1
11-06-2007, 08:55 PM
Im interested in the PAC 1218s for $165 shipped
do these require a retainer for use with 1.6RR's on stock cam/heads?
Shon Herron
11-06-2007, 10:02 PM
yes, you will need the smaller retainer for the beehive, do you want Ti Retainers or steel? We can get it all to you.
bad6as
11-12-2007, 08:56 PM
how much for TI retainers?
and who makes them?
Shon Herron
11-12-2007, 09:18 PM
and who makes them?
Comp would be the company I use, unless you have another preference.
$265 shipped.
Shon Herron
11-13-2007, 03:21 PM
Springs have arrived.
Alex99
11-14-2007, 09:33 AM
Excellent.
How do we proceed now?
Shon Herron
11-14-2007, 10:20 AM
Excellent.
You can paypal me directly at shon@herronperformance.com or PM me a # to call and I can take CC info over the phone.
rpm4lalo
11-14-2007, 08:50 PM
I am interested in the PAC-1518 as well. I have comp 918's on my car now with steel retainers. It only took about 90-100 miles for 3 of them to break. Unsettling to find that when you pull a VC. All I would have to do is change the springs ad reuse my locks, retainers and spring cups right?
Also, was interested in a price for a SJM LL with abs delete kit.
Also needed some parts for my moser 12 bolt, you deal in those rear ends?
rpm4lalo
11-14-2007, 09:06 PM
PM sent because I forgot about a price on Hawk HPS pads for my ls1 brake upgrade.
Yeahdoug
11-15-2007, 10:46 AM
1518s will swap right in.
Shon Herron
11-20-2007, 08:12 AM
a FEW springs left.
