waite1of4
10-28-2007, 09:43 AM
Need the correct sizes for 9.5 rims for z06 17 front and 18 rear. Looking to keep stock height. Email me with any pics you may have of yours. waite1of4@yahoo.com
correct fittmentwaite1of4 10-28-2007, 09:43 AM Need the correct sizes for 9.5 rims for z06 17 front and 18 rear. Looking to keep stock height. Email me with any pics you may have of yours. waite1of4@yahoo.com Injuneer 10-28-2007, 12:32 PM What year car? What tires were on your car originally? It would help if you had a "signature" with basic info about the car - year, model, engine, tranny and any major mods. There were 4 different tire sizes used on the 4th Gens (assuming that's what you have): 215/60-16 = 26.2" 235/55-16 = 26.2" 245/50-16 = 25.7" 275/40-17 = 25.7" waite1of4 10-29-2007, 12:42 AM My car was a 16 inch wheel 93 z car. Currently has 275-40-17 all the way My main concern is the 18s. Have no clue on that signature thing and how to do that. Thanks Kris Injuneer 10-29-2007, 11:38 AM An 18x9.5" wheel can run: 275/35-18 = 25.6" 285/35-18 = 25.9 295/35-18 = 26.1 (technically, this tire needs at least a 10.0" wide wheel) The stock tires on the Z were 235/55-16. You only got the 245/50-16 tires if you opted for the Z-rated tires (RPO QLC). Check the sticker on your door.... it should show the original tire size. waite1of4 10-29-2007, 12:57 PM Yes I had the up option z rated code. does anyone with the .1 shorter tire notice a diffrence in looks? Injuneer 10-29-2007, 01:52 PM The difference is split over the two sidewalls, so you are talking about a 1/20th of an inch difference - very hard to see. Also, each manufacturer sets his own dimensions. Those are typical of many manufacturers, but not all. The "nominal" diameter can vary +/- 0.10" from one manufacturer to another, or even within the different tire models from the same manufacturer. waite1of4 10-29-2007, 05:28 PM Thanks allot, this eally helped, I believe I will go with the .1 shorter, and just look thru tire rack and find the ones that are about the same exact. Appreciate all the help. Kris | ||
