what would a ls1 sound like if a 918 spring was bad?
Old Oct 23, 2007 | 11:57 AM
Klypto's Avatar
as title says
Old Oct 23, 2007 | 02:20 PM
Marc 85Z28's Avatar
It would sound like time to pull the valve covers.
Seriously, diagnose a possible valve spring failure with a visual inspection, not by the sound it makes. If you have a rocker or pushrod failure which could have the same symptoms as a failed spring, pulling the covers would tell you. Its a 10 minute job...
Old Oct 23, 2007 | 02:43 PM
RE AND CHERYL's Avatar
If the car is still running and you have to ask, you probably don't have a broken spring.
You would know it if you broke a spring. If you were lucky you would only get a bent valve stuck in the head. If you weren't, you would trash the head, the piston, and possibly a cylinder sleve/block.
Re'
Old Oct 24, 2007 | 05:02 PM
Greed4Speed's Avatar
A friend of mine broke a 918. The valve dropped and all said and done, the only thing in the long block that was salvagable was 1 head. IIRC something even cracked his intake.
Remove your coil packs and pull the cover and take a look. The gasket is reusable so it'll only cost you time.
Old Oct 24, 2007 | 06:31 PM
Bayer-Z28's Avatar
Where's Mike94ZLT1?? He had an incident w/ CATASTROPHIC valvetrain failure!!! holes in pistons.. I can't find the thread.. It was in here.. Somewhere.
If you broke a spring, it'd be running on 7 or less cylinders. Broken spring = no compression = No valve head in the correct place to seal off the chamber = (risk of) valve falling into cylinder. Valve falling into a cylinder can break the valve head off, cause the valve stem to fall into the cylinder, the the stem would bounce around till punching a hole thru a piston.. THat's if the locks stay on the retainer which in the event of a broken spring, isn't too likely.
Old Oct 24, 2007 | 06:35 PM
dangalla's Avatar
in the time it took me to write this you could have had your valve covers off to check. do not screw around with this, horrible things can happen
Old Oct 24, 2007 | 07:04 PM
Bayer-Z28's Avatar
THis is what can happen if you break a Spring.. Not quite as bad, but you get the idea.. Only limited to one or two cylinders, depending on how many springs break..
Originally Posted by Mike94ZLT1
WOW... I just pulled the drivers head and nearly crapped my pants... I need a beer or three...
Old Oct 24, 2007 | 07:06 PM
dangalla's Avatar
honestly i teared up a little looking at those pics, horrible destruction
thats one way to scare him into checking
Old Oct 24, 2007 | 07:09 PM
Bayer-Z28's Avatar
^ Exactly! I almost threw up when I first saw this thread back when it happened.. All from leaving the Rocker seat things out.. GAWD!!
Old Oct 25, 2007 | 09:07 AM
Kraest's Avatar
Retired
There's a sticky that I placed at the top of this forum warning people of using those springs a few months ago.
Sorry, Cory, but more than likely you have a broken spring if that's what you possibly think it is. Pull the valvecovers.
The two best choices in my opinion for most buildups are the Patriot Golds or the PRC Duals.
Mike
Old Oct 25, 2007 | 09:43 AM
dangalla's Avatar
any reason you dont like the pac 1218 or 1215
Old Oct 25, 2007 | 11:57 AM
[b]
Mike
Which is made by the same company.
Old Oct 25, 2007 | 12:18 PM
Kraest's Avatar
Retired
I've just never used them.
I'm not saying they aren't good springs --- I'm talking about personal experiences.
Old Oct 25, 2007 | 12:33 PM
Klypto's Avatar
this was taken a few days ago... prob not broken eh? but it still runs like ****. idles fine, once hits 2krpm it missfires bad, till 2800-3100ish then most of the time it clears up and pulls, but i cant even drive it. it badfires a good pit when driving. smells bad of gas...
can this all be just a tuning issue? or not sure without messing with it/testing it?
cory
Old Oct 25, 2007 | 01:21 PM
Tell us a story.... What's in the car? Is it tunned or on the stock tune? When and how did the problem start? What have you done to fix it?
Idea. This didn't start after you washed the car,did it? My car was doing nearly the exact same thing. I had washed the car and somehow got water into the connectors on the PCM.
Re'
