True duals?
Old Oct 18, 2007 | 06:31 AM
FatBoySpecial's Avatar
True duals?
Anyone think the Camaro with have true dual exhaust this time? Personally I hope they do. Alot more you can do to tune exhaust if you have a mid pipe to mess with! Not to mention it would smooth out the exhaust pulses.
Old Oct 18, 2007 | 06:42 AM
JasonD's Avatar
Admin Emeritus
I think there is a good chance it will.
Old Oct 18, 2007 | 09:11 AM
Z284ever's Avatar
I think they will as well. I'm just not sure what the big hang-up is with "true duals" though.
Old Oct 18, 2007 | 12:12 PM
99SilverSS's Avatar
The concept Camaro's did. I would think the platform the Camaro rides on with IRS would be very conducive to dual pipes and sperate mufflers.
Old Oct 18, 2007 | 02:08 PM
SharpShooter_SS's Avatar
That may depend on your definition of "true duals" I suppose. Is it separate pipes and converters from the manifolds/header all the way back to separate mufflers? Or is it manifolds/headers and/or converters into a single pipe breaking off into two again before the rear wheels into separate mufflers?
My take on it is separate pipes all the way from the manifolds to the exhaust tips - crossover pipe notwithstanding.
Old Oct 18, 2007 | 08:29 PM
99SilverSS's Avatar
That's the way I expect it to be. We shall see.
Old Oct 19, 2007 | 11:11 AM
jg95z28's Avatar
Agreed. A well engineered and tuned exhaust is a well engineered and tuned exhaust.
Old Oct 19, 2007 | 03:30 PM
RussStang's Avatar
Why do Vettes sounds better than fbodies, even with the same exhaust setup? A large reason is simply because the Vette has a true dual system the whole way back, with a crossover pipe.
An fbody with true duals definelty sounds different than an fbody with the stock suspension setup.
Old Oct 22, 2007 | 04:16 AM
90 Z28SS's Avatar
The Zeta cars have a true dual exhaust , I dont see why the Camaro would be any different . The old 3rd and 4th gen exhaust was a complete compromise due to limitations in the floor pan . Designed in the late 70's early 80's and basically never re-engineered , there really was no need for true dual ... hence the famous converter hump and single piping .
Old Oct 22, 2007 | 10:59 PM
DAKMOR's Avatar
Gotta love the hump!!
If any model turns out to be y-piped, I figure it'll be the base model. And that shouldn't be too hard to engineer, all you got to do is connect them somewhere before the firewall(over/under transmission) and have the pipe run down one of the cleared pathways for exhaust system.
Of course, engineering such a thing might be too costly and may make maintainence difficult, so perhaps all models will have dual exhaust.
Old Oct 23, 2007 | 04:31 AM
Capn Pete's Avatar
It wouldn't surprise me in the least if the V6 cars (if nothing else, the base/entry V6) have a single exhaust (ie: Y-pipe). If there is room for duals, there's room for a single! That would basically cut the cost of the exhaust system to nearly ~50%! Sounds "economical" to me!
As seen on the concept, I fully expect a true dual system on the V8 cars. A cross-over pipe wouldn't surprise me though either ... I'm sure that may be a tool used to "tune" the exhaust from the factory .
Old Oct 24, 2007 | 04:09 PM
Z/28lover's Avatar
I can only hope....
Thats the single reason the Vette sounds sooo much better than an F-body.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
