Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Hal 12 and 24 Way Adjustable Shocks On Sale!
Old Oct 16, 2007 | 05:28 PM
tbyrne's Avatar
We have discounts available for the complete line of Hal products. They produce 12 and 24 way adjustable shocks for the f-body. Pricing is lower than they allow us to advertise but you can receive a quote by e-mailing tbyrne@tbyrne.com or giving us a call at 1-877-482-9763. Part numbers are listed below.
Generation-F Front
QA1 Motorsports has the single best front shock available for GM F-body cars (1993 – present Camaros and Firebirds). Street, strip, or handling, this is the shock that can do it all! The GEN-F provides machined aluminum, externally adjustable shocks designed specifically for this series chassis. The valving adjustment is made with a single **** at the base of the shock (12 settings total), enabling you to adjust to changing track conditions or for ride comfort. This shock is the dominant force at the track and on the street.
The GEN-F shock is machined aluminum, bright anodized, and incorporates No. 8 Acme threads for easy ride height adjustments or adding preload to the front suspension. Based on the Proma Star AL, (see page 5) the GEN-F series uses the same 5/8” centerless ground, hard chrome piston rod for unmatched precision. Another plus, as with all QA1 Motorsports, is that the GEN-F is completely rebuildable and revalvable for a lifetime of service and customizing.
The sealing system in the GEN-F series rivals the best in the industry. It is designed to nearly eliminate seal drag, yet handle the rigors of everyday use. The GEN-F is simply the most versatile front shock available on the market today for 1993 – present Camaros and Firebirds.
OED-7855-P
Generation-F Rear
GM F-body cars’ (1982 – present Camaros and Firebirds) chassis design uses a torque arm suspension, differing them from the rest of the crowd. That’s why QA1 Motorsports has also designed a superior rear shock specifically for this series chassis. The GEN-F rear shock is engineered to handle it all – from drag and road racing to everyday street use.
The GEN-F offers a wide range of valving adjustments (12 settings) through just one ****. This bright anodized, machined aluminum, externally adjustable shock utilizes the same quality pieces found in all our shocks – 5/8” triple chrome piston rod, the highest quality fluid, and individual dyno testing. The sealing system is the best in the industry – it nearly eliminates seal drag, yet easily handles the rigors of everyday use. Plus, GEN-F rear shocks are rebuildable and revalvable for a lifetime of high performance use and customizing as you update.
TC-2501-P
12 Way Adjustable Shocks -
Double Adjustable Front F-Body Shocks
• Ride Height Adjustable Directly threaded body allows for stock or Aluminum shock with 576 valving options. Allows truly independent adjustment of compression and rebound. 24 positions of compression adjustment on one ****, and 24 positions of rebound adjustment on the other ****. Each **** is clearly labeled with an "R" for rebound or a "C" for compression, as well as plus and minus symbols for ease of adjustment.
Front F-Body Springs
QA1 offers the perfect springs for 1993 - 2002 Camaro/Firebird front suspensions using the GEN-F front shock. QA1 now offers three spring choices for your Gen-F vehicle. Purposely built with factory and modified small block cars in mind, the springs below are designed to set on the GEN-F spring seat and fit into the factory location at the top. When used in conjunction with the GEN-F front shocks, they are unmatched in ease of installation and performance.
- 275 lb. spring Drag Racing
- 300 lb. spring Nice Ride & Handling
- 325 lb. spring Firm Ride, Great Handling & Cornering
Double Adjustable Rear F-Body Shock
Aluminum shock with 576 valving options. Allows truly independent adjustment of compression and rebound. Includes Lower shock bolt.
OED7855P Hal Single Adjustable Front Shock (12 Way Adjustable)
DOE7855P Hal Double Adjustable Front Shock (24 Way Adjustable)
RC7855P Hal Front Shock - Drag Racing Only
TC2501P Hal single Adjustable Rear Shock (12 Way Adjustable)
DTC2502P Hal Double Adjustable Rear Shock (24 Way Adjustable)
15FB275 Hal Front Drag Springs - 275# (Recommended for LS1)
15FB300 Hal Front Drag Springs - 300# (Recommended for LT1)
15FB325 Hal Front Drag Springs - 325# (Recommended for Handling)
T114W Hal Spanner Wrench (Recommended)
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR OUR EVERYDAY LOW PRICE POLICY!
Old Oct 17, 2007 | 09:13 AM
tbyrne's Avatar
A little more info -
Old Oct 28, 2007 | 07:12 PM
wicked_95z's Avatar
Has this sale ended??
Old Oct 29, 2007 | 09:27 AM
tbyrne's Avatar
It's still going!
Old Oct 29, 2007 | 09:31 AM
wicked_95z's Avatar
Ill give you guys a call
Old Nov 6, 2007 | 07:44 PM
wicked_95z's Avatar
Are these shocks on backorder??
Old Nov 7, 2007 | 09:36 AM
CSJTA's Avatar
Tom, please PM me a price on the I5FB300 Front Spring
Thanks,
Chris
Old Nov 8, 2007 | 08:19 AM
tbyrne's Avatar
We have some Hal part numbers in stock. Currently don't have a complete set for the f-body right now.
Old Nov 8, 2007 | 06:26 PM
95Bluestreak's Avatar
You have e-mail!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
96SilverRam
May 5, 2015 09:56 PM
Victory Racing
Apr 19, 2010 06:08 PM
MislMan
Jul 19, 2002 11:41 AM
