Gauging interest in 94 camaro Z28
Here is a link pictures.
http://allentown.craigslist.org/car/451032998.html
I have been thinking about possibly selling my 1994 camaro z28. Below is some info on the car and some pictures. We can negotiate on the price with the aftermarket parts, etc. The car runs very strong, I have had this car for 6 years. It was completly stock when I purchesed it. It is loaded with power drivers seat, windows, locks, keyless entry. However the passengers side window motor is dying. I can fix this our we can work it out in the price. I am thinking about moving onto a new project car. Open to trades also. I did a compression test about 5k miles ago and all the cyl were around 205-210psi which is well within range. Make an offer, serious inquires only. Or call me 610-533-3920.
Black 94 camaro z28 T-Tops - 5.7L, 127k miles - Tan interior
4l60e transmission with 40k miles -
2400 stall torque convertor -
Rear was rebuilt with 373 gears, 25k miles -
Ac delco opti spark was replaced 20k miles ago -
Fixed rear intake manifold leak 1k miles ago -
Mezire electric water pump (still have the factory water pump with 25k miles) -
Coated pacesetter 1 3/4 long tube headers, y pipe (headers have some rust) -
Magnaflow stainless steel cat back exhaust -
Pcmforless tunning (I have a laptop, cable to hook up to the car to scan, and load new tunes into the car for furture modifications) -
Msd wires, blaster coil, ngk plugs - have about 1k miles on them -
Holley air foil -
Walboro 255lph fuel pump -
Moroso cold air intake -
Lakewood lower control arms -
Comp. engineering strut tower brace -
Crome radiator shroud -
Front and rear headlight covers -
5 star wheels from a 95 trans am -
Driveshaft safety loop, tunnel brace -
B&M transmission cooler -
Billet grille -
Clear turnsignal lights, I have the factory lights also -
Parts not istalled:
Crower cam - specs 221/230 560/580 lift with 1.6rr's -
Comp cams pro mag 1.6rr's -
Comp cams lifters -
Lunatin timing chain, gears -
CM612 valve springs with locks, retainers - good up to 600 lift -
Also have the factory wheels
Holley air foil -
Billet grille -
Parts not istalled:
Comp cams lifters -
CamaroHeed
Mar 18, 2020 09:50 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
