5 speed interchange
nevermind65
10-09-2007, 07:46 PM
I have a 350 in my car with a Borg Warner T-10 behind it. It has a blowproof bellhousing with a hydraulic clutch set-up. I would like to install a 5-speed to get the O/D. Does anybody know which trans might bolt up to this bellhousing and be able to about 400-450 hp?
Thanks in advance.
thesource2004
10-09-2007, 08:44 PM
You have two choices that come to mind right off hand .
One would be a built T5 using Astro Performance A5 gears and the other would be a Tremec 600 (chevy version) .
Both are expensive but both should bolt up to your bellhousing . Your other option is a T56 unit with an adapter to bolt up to the bell housing as well .
