Hesitation out of the whole...
waterbug1999
10-08-2007, 04:31 PM
Any ideas what would cause this hesitation with the N20? You can see it in the vid. Purged it plenty and it just started doing this as of lately. But, still managed a 10.95 though. Thanks.
http://i188.photobucket.com/albums/z164/waterbug1999/th_BIROCT6008.jpg (http://s188.photobucket.com/albums/z164/waterbug1999/?action=view&current=BIROCT6008.flv)
Z-RATED94
10-09-2007, 11:39 AM
Maybe the car thinks it knows what's best, and does this, so as not to break traction? ;) Nice times.
waterbug1999
10-09-2007, 01:02 PM
LOL...
AutoRoc
10-09-2007, 04:59 PM
fuel pressure safety switch psi too close to operating pressure? Fuel pump not working as well, causing slightly lower pressure? just ideas...
waterbug1999
10-09-2007, 05:53 PM
I had the FPSS hooked up and it would not spray, I guess its set too close to the fuel pressure, so I disconnected it and it worked after that.
I have a walbro 255 in the tank, so that should be fine.
I have had the N20 system on all summer and it was fine up to this point. I did not change anything on the window switch..
Only thing I can think of is I had to pull the carpet back under the pedal for the N20 pressure guage I added (to run wires).. I am startin to think that the reference volt the WS needs to activate is somehow off by .1 volt at the initial stabb of the gas pedal.
