1995 Formula w/many extra's for sale
5.7LT1Formula
10-05-2007, 04:04 PM
Selling the car in my SIG and Extra blocks/parts for one price! Buying house and i would like to sell the car and parts as one transaction.
$9,000.00 OBO
Please Email me at ryanfree@onlyinternet.net as i do not visit the list often pics available soon.
95 Formula A4 White with Black leather Interior, Stored inside most of the time and stored durning winter months, White SS Rims, New Tires,White Face Gauges, Lingenfelter CAI,TPIS ZZ9 Cam,Lloyd Elliot Port and Polished LT1 Alum. Heads, Ported MAFS, TB Bypass, 1LE Elbow, 160 Hypertech Stat, CSI Waterpump, BBK Shorty headers, Gutted Cat w/3in Ypipe, PCM Forless Tune, Brembo Blanks/Cross Drilled & Slotted, Russel Stainless Brake Lines.Moser 12 Bolt w/ 3.73
Right now the car has a 350 with the following build.
350 LT1
LPE CAI, TPIS ZZ9 Cam, Comp R Lifters, Lloyd Elliot Port and Polished LT1 Alum. Heads, 1LE Elbow, 160 Hypertech Stat, CSI Waterpump, BBK Shorty headers, Gutted Cat w/3in YpipePCM Forless Tune, Brembo Blanks/Cross Drilled & Slotted, Russel Stainless Brake Lines.Moser 12 Bolt w/ 3.73
Rear end build:
Houseing: Moser
Axels: Moser 33 spline and gun drilled
Posi Unit (believe it to be an Eaton Posi)
3.73 Gears
All new bearings less than 800 miles ago.
Trany Build sheet: (updates coming soon to this list)
built in 2005 has less than 2,500 miles
New Stock Vette tork Converter
Vette Servo
dual race sprag
Hardend input shaft
.060 boost Valve
Extra 1-2 clutches
B & M Shift Kit
MORE INFO TO BE ADDED SOON...
Extra parts that come with car:
LT4 Timing set
2 stock 95 cam's
1 stock LT1 Block (sum surface rust)
1 LT1 block .030 over (Bored w/ torque plate) new cam bearings, freeze plugs Clearanced for 383 crank w/ 5.7 rods(Clean)
2 sets of stock lifters
1 95 Opti w/ plug wires
2 AC Pump's (1 good, 1 needs rebuilt)
1 LT4? High Torque Starter (only a few months old)
1 LT1 Alternator (supposed to be high amp out of police car)
1 stock LT1 Crank
stock 10 bolt (only 1 axel,housing and cover can be rebuilt or junk it)
1 set of Cast Iron LT1 Heads
1 stock Y pipe (no CAT)
1 Melling HV oil pump w/ ARP pump shaft
1 set of Stock Valve covers
1 Stock Water pump
1 Stock Coil
1 Stock timing cover
1 Stock oil pain (has dent in bottom of pan can be pressed out)
1 stock Intake (Complete w/ TB, fuel rail and injectors)
1 Power Antenna
1 set stock manifolds
Following need machining
Lingenfelter Balanced this assembly when it was new
(Bad tune w/ no rev limit hit 7000RPM spun rod bearing)
1 set stock Rods w/ ARP Bolts
1 Eagle 383 crank (spun rod bearings)
1 set of 8 Keith Black Model 124 Hyper-retec Pistions (one piston needs replaced) (Bosh Plat.plus4 plug Electrode split in half burning a hole in piston)
