Power antenna swap
Old Oct 3, 2007 | 12:19 AM
Darin M.'s Avatar
Power antenna swap
What does it take to swap the power antenna from a Firebird(1998+) to a Z28(1996) that never had one? I found the antenna/motor unit with the wiring to the connector. Right after the connector the wires are cut. Is this a simple plug-in?
Thanks!
Old Oct 3, 2007 | 04:21 PM
TraceZ's Avatar
You will need to wire it. The Camaro harness does not have the wires in it.
4th gen Camaro was never offered with a power antenna mast.
Old Oct 3, 2007 | 05:20 PM
camarozz95's Avatar
If you have the stock head unit I don't think it will work, But if you get a aftermarket one it should my aftermarket head unit had a wire to hook up a power antenna.
Old Oct 3, 2007 | 09:06 PM
TraceZ's Avatar
The stock radio has a power antenna lead, you just have to hook into it at the back of the radio.
I use it as a trigger lead for my amp.
Old Oct 6, 2007 | 08:27 PM
Darin M.'s Avatar
It's probably more trouble than it's worth; I really hate to wire anything.
Thanks, though.
InfernalVortex
Jan 17, 2015 09:35 AM
siguy
Nov 27, 2014 10:07 AM
XtremeLt1
Sep 13, 2002 08:50 PM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 3, 2002 07:29 PM
