A4s Beware!
Old Dec 3, 2002 | 09:42 PM
blu94Z's Avatar
Thumbs down A4s Beware!
We just got in two brand new '02 Z28s (Police Package, B4Cs I believe is the option) for our chase car duties here at Beale AFB. Yesterday, as I went out to the ramp to fly my sortie, I saw one of the new Z28s sitting on the side off the ramp. It only has about 2K on it and the transmission was blown! Of course we run the cars, REALLY hard here at Beale, typically full throttle accelerations up to 100 mph then back down when chasing the airplanes on landings. On a typical touch and go type sortie, we will probably do 5-10 run-ins. Anyway, the point failure with the car will be the transmission, which would be expensive for a private owner. Out of curiosity's sake, has anyone out there had to replace or rebuild their A4 transmission. All of you out there with the A4s who race them on the street or strip, watch out and make sure you don't abuse the transmission too much.
Steve
Old Dec 3, 2002 | 09:52 PM
V6toZ28's Avatar
350+ launches ... no issues so far. Blew out #5 cylinder though
Old Dec 3, 2002 | 10:12 PM
BISHOP's Avatar
I have a bit over 8000 miles on mine with no problems, ran a few bottles and went 11's on a tire. Sounds like abuse to me. Are you guys trying to manual shift them or something?
Old Dec 3, 2002 | 10:15 PM
blu94Z's Avatar
Nope, just put them in "Overdrive" and stomp on the gas (to the floor). They catch up real quick. Of course, without proper planning, I have been left FAR behind the jet on occasion.
Steve
Old Dec 4, 2002 | 12:12 AM
Camaro ChriSS's Avatar
Try installing tranny coolers on the LS1s.
I've had no probs and I run a high TC (3500). Usually the only A4 problems are from massive hp/tq cars (100 over stock) that are run hard with a high stall converter. 98% of the owners I've talked with (Over 1000) have had no serious problems, unless serious torque was being used.
You may have just had an isolated occurrence. Bad luck, as it were.
Old Dec 4, 2002 | 03:00 AM
TerrorDome's Avatar
my '98z a4 has 37.800 miles and no problems so far. I just change the tranny fluid every two years. the diff. w/2.73's every yr. it leaks
Old Dec 4, 2002 | 03:40 AM
AL SS590 M6's Avatar
Moderator
2000 Formula
24,000 miles
371 quarter miles passes
And ran the number in the sig.
Yank ST3500
TransGo
B&M cooler
Old Dec 4, 2002 | 08:32 AM
SS_Thunder's Avatar
Sounds like a rough job...where do I sign up
Old Dec 4, 2002 | 12:32 PM
guywidiroc's Avatar
I have never had the slightest problem with the A4 trans on the 98 z28, 00 z28, or 02 z28. I think this is a well built tranny, just needs to be broken in properly, like the motor. I beat on mine pretty hard too, no granny driver here.
Old Dec 4, 2002 | 02:21 PM
blu94Z's Avatar
I think the B4C package, or at least our Z28s, have the transmission coolers, anyone know the RPO code for this on the driver's side door sticker? Now that I'm hearing in the neighborhood of 300-500 1/4 mile passes, I guess the abuse we subject our cars is far greater than anyone would at the track. With 2000 miles, one of our Z28s will typically have 500-700 full-throttle run-ins which will last 1/2 to a full mile and then the return trip back down the runway again.
Steve
Old Dec 4, 2002 | 03:26 PM
nikkev's Avatar
Question
Aren't the cars suposed to be left in D and not OD?I know that's the way I run at the track.Probably means nothing though.If you are constantly running the cars and not letting the tranny cool down between runs then you may need a bigger tranny cooler.A $50 cooler is MUCH better than a $2,000 tranny rebuild.Heat is what kills trannies.Good luck.
Kevin
Old Dec 4, 2002 | 06:14 PM
katman's Avatar
Steve,
24K on my 02, lots of full throttle passes, and zero tranny probs.
Here is the link to the 2002 RPO codes, it doesn't list a tranny cooler as a standalone, but it may be part of the B4C package
RPO codes
You boys oughta quit giving the U2 a break on the Christmas tree and take it from a roll! (I miss the El Caminos)
Old Dec 4, 2002 | 07:40 PM
94B&RZ-28's Avatar
Re: A4s Beware!
Steve
Yah and I have to take the damn cars down to Yuba Trans everytime you guys fry them I'm on Morans waiting list, when is my incentive ride???
9 Trans..Dirty Trans.....
Old Dec 4, 2002 | 07:42 PM
94B&RZ-28's Avatar
Steve
Theyre all B4C packages. Vehicle Maintiance just started putting the tranny coolers on the 99's I believe. How you boys liking the cross drilled and slotted rotors we installed?
Old Dec 5, 2002 | 12:23 AM
dmnall's Avatar
Exclamation
Sounds to me that you just gotten a bad tranny since the 4L60E is in these cars, these trannys are not like the 700r4 (4L60) which had a problem of being too weak compared to a TH350 or even TH400, GM did put more clutch packs in the 4L60E tranny to make them a more durable tranny. Again nothing is perfect but they do break down.. Also Tranny Cooler is in the Radiator but I would say put a bigger Tranny Cooler on if you are worried about it.. I have seen TH350, TH400 (experienced one losing Drive and 2nd), 700r4 and 4L60Es go out.. The main area where 4L60Es go out is their servos in the valve body can burn up and then, your tranny will not shift!!
This is information that I was told by both an independant Transmission Rebuilder and a Transmission Tech over at a Local Chev Dealer...
