95blowntaconvt
09-23-2007, 07:13 PM
Click on the links for a description
1995 Trans Am Convertible $1000 (http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=140161184126&ssPageName=STRK:MESE:IT&ih=004)
LT1 Racing Engine $2500 (http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=140161169157&ssPageName=STRK:MESE:IT&ih=004)
Located in Orlando Florida
I'll work out shipping with anyone in central florida
dangalla
09-23-2007, 07:15 PM
both links are for the car
maverickmk
09-23-2007, 08:18 PM
What does the car need other than a motor and trans? Are all the other things working? Air, brakes, rear end, interior in good shape, etc. Just trying to get an idea of the shape it's in - what it will need to get it on the road.
95blowntaconvt
09-23-2007, 08:50 PM
The car does not have the engine or engine accessories in it
The rest of the A/C stuff is there but it's not capped off.
If you dont have a distributor or a crank/cam sensor, you'll need to send the speedpro back to FAST and have them change it to use the optispark. Or you can unsplice the speedpro and use the stock computer with LT1 edit. I'll give you my last copy of the LT1 edit software. I believe you can still use EDist with the stock computer if you want a coil per plug.
The transmission needs to have the 3/4 clutches replaced. All the internal componants are upgraded.
The only thing wrong with the interior is the normal wear on the side of the seats from getting in and out. It doesn't have a radio installed either. The rear portion of the roof will at least need to be replaced, unless you know how to glue the window back in.
If anyone wants to take a look at the car I'm available from 10:00 am until 2:15 pm
