Dtimekw 09-20-2007, 08:30 PM My A/C seems to work fine when I first start the engine. After a while, the compressor stops turning. One of two things seem to cause this. I have notice that under a high rev condition (1st, 2nd gears revved up) the A/C stops working. Another thing I noticed today, I first started the engine, A/C compressor kicked on. I shut it off and drove around. After the car has warmed up and was driven for a good 30 mins, the compressor wouldn't kick in. I live in S. Fla, air temp was about 92 today. System was just charged. When the compressor does kick in, it is pretty cold. Any ideas? I am dying down here.........:cry:
RedWS6TA 09-20-2007, 08:54 PM does it freeze up? if so it could be the cycle switch that is not working properly
n2ceptor 09-20-2007, 09:06 PM If you are sure the freon level is correct(IE checked with gauges), check the clutch cycling switch..... It might be bad or loose conection????
MeanGreen97Z 09-20-2007, 09:16 PM Was it working better before the recharge?
Dtimekw 09-20-2007, 09:21 PM It was recharged after the engine swap. Had the same problem before though. What is a cycle switch? Where is it? What does it do? At this point, I am ready to replace all sensors and switches. I just don't know where/how many there are.....
n2ceptor 09-20-2007, 10:44 PM http://shbox.com/1/refrigerant_sensor.jpg
Courtesy of Shoebox..:)
Dtimekw 09-21-2007, 07:14 AM I'll check it out, thanks, and thanks to Shoebox AGAIN :bow:
stephenspann27 09-23-2007, 12:22 AM You can check that sensor by putting the car on a scanner and checking the A/C pressure, when my sensor was bad it read 0psi, which disables the a/c clutch. My new sensor only lasted a week for some reason...
Dtimekw 09-23-2007, 07:45 PM Not sure I get what you mean. I scanned the car and it threw a several codes, 66,67 and something about a transducer. I cleared the codes (didn't write them down like an idiot :mad:) and the only one that came back was 67. I check the resistance between all 3 pins before and after the problem and the resistance was the same. What else could cause this? It is getting hot down here in South Florida..............HELP:cry:
stephenspann27 09-24-2007, 12:29 PM The scanner I have allows you do view "operational" data. Real time data like RPM, vehicle, speed, O2 stats. I"m also able to view the A/C psi. and when my sensor was bad it read 0psi instead of the 200-250 it should have. The sensor is about $60... You if you had a new one or, a friends you could compare the Ohms across the pins, or slap one in off a buddies car. You won't loose any refridgerant when replacing it, there is a schrader valve
stephenspann27 09-24-2007, 12:56 PM So I just fixed my car. I had enlarged the connectors on the plug that goes into the pressure sensor when I jumped it with the wire. So it wasn't making a good connection on the sensor
Dtimekw 09-24-2007, 06:58 PM Still pulling my hair out. I replaced the sensor, figured it was worth it. No joy. As I scan, I can watch A/C demand turn on when I turn on the A/C and then a second later A/C clutch turns on but no cold air.
When I started the car this afternoon after replacing the sensor, the A/C was ice cold, cycled on and off for about 10 minutes in the garage, figured I fixed it, took it for a test spin and not more than 2 minutes from the house, it quit. It threw a code 67 again. Both fans are on and running. Are there any other sensors that could cause this? I've tried to jumper the relay but no joy, which two do I jumper????
Dtimekw 09-24-2007, 10:28 PM I added a small can of 134A tonight and ran it at idle for over 30 mins with no problem. I put a temp gauge in the vent and got a cold 58 degrees. I will take it for a test drive tomorrow but want to know if anyone else has had this problem?? I don't want to take it to the shop but I am running out of ideas.........
