Why is this so difficult...turn signal replacement?
IRONFIST
09-16-2007, 01:41 PM
So I'm not sure why this is so hard, but I can't seem to get the old turn signal out....
I found the clip, I've pushed it in, tried to turn it, tried to pull it out.... nothin works?? :confused:
IRONFIST
09-17-2007, 10:19 AM
Well finally figured it out... if anyone ever has this problem, it's a lot easier to undo three bolts on the plastic curve at the bottom of the car, squeeze an arm in and pull the bulb out.
OMGWTFBBQ
09-17-2007, 11:54 AM
I never had any trouble.
The foglights are much harder.
lastZ
09-19-2007, 09:18 PM
how did u try to do it before u figured out that little trap door?:)
OMGWTFBBQ
09-25-2007, 12:09 AM
Wait, turn signal? I just reached in the inlet below it and popped it out.
Was easy once I figured out how to turn it.
bluzboy
11-18-2008, 05:29 PM
I still can't get mine out '99 camaroSS......Underneath are you talking about the plastic splash guards(?) Or Reach in from the top.....looks like you need to remove Headlamp assembly!!!!!Haven't done that yet!
bluzboy
11-18-2008, 11:27 PM
Finally got it after an hour , from the bottom. Got pliers on it to start turning 1999-2008; I'd love it if these damn CFL bulbs would last half as long!!!
IRONFIST
11-19-2008, 12:41 AM
yah it's a pain eh, hopefully this thread helps everyone out when they search.
OMGWTFBBQ
11-24-2008, 12:02 PM
Jeez. I've never had any trouble. And I got one that fishbowls.
Reach in the slit underneath the housing, and pop it out.
97lt1fanatic
11-25-2008, 12:22 AM
lol the way i did mine was turn on the lights put my arm down underneath the light from right beside it and pop it out but i got pretty small arms.
johnny6
11-25-2008, 03:14 PM
On 98-02 Camaro's i just pop the headlights out (5 minutes at the most) and everything is right there, i can do both turn signals and foglights in less than 10 minutes.
