1989 IROC Red 350 Ttops NY/PA
SOLD
This car will make a very nice driver. Its not a show car by any means but it has some fresh paint and runs great mechanically. It has some rust on the driver fender on the botom. Some under the hatch. Has a brand new headliner. 4 Good tires. I have lots more pictures if you want them. hende80@yahoo.com or 607-972-7419-Gregg
any interest
let me know if your interested in a trade
I built this to keep forever so everything that went into it was the best I have only 1500 miles on it since everything was put back together.
looking to get 7500 picked up in maryland or trade for something in ok shape maybe a jeep wrangler or clean driveable stock 5 speed 3rd gen w.t-tops. email if intersted I can send pics. I am going to post here a gauge interest if I can;t get this much I may consider stripping car selling parts.This has been mid 12's on bad street tires the engine is built for a 200 shot of nitrous. I have invested close to 15k in the car over the last 3 years but the wife says it has to go. So review let me know if your interested I know we got some distance but if interested maybe we can work that out.
thanks for looking
eddie
240-216-0063
esymonds1@comcast.net
95 z-28 106000
built 96 vette 4 bolt main block
forged 30 over pistons
11.0-1 comp
shot peened rods
arp rod bolts
stock crank size(was perfect when rebuilt)
high pressure gm oil pump(holds 45 at idle 65-70 at 2000)
6 quart vette oil pan
lt4 cam kit with gm roller roackers
manley valves
hardenes comp pushrods
new gm perf parts lifters
stock lt1 heads port matched to intake
jett hot coated intake manifold
jett hot coated edelbrock shorty headers
58 mm edelbrock throttle body
all new sensors
egr removed & blocked off
polished valve covers with correct notch for alternator
moroso cold air intake
new vented optispark upgrade
taylor 10mm wires
new ac compressor
new ac lines
repainted engine compartment
aluminum radiator
steel braided transmissions lines with all fittings
lt1 edit program with customer flash cable
built auto 4l60e with extra clutches shift kit installed
new u joints (stock drive shaft)
stock locking rear
new brakes up front(calipers,pads,rotors,brake lines)
new suspension techniques bushings front & rear
new ball joints tie rods
traction bars
KYB AGX adjustable struts & shocks front & rear
new strut boots
new steering rack
abs removed & proportioning valve installed with line lock kit(steel needs to be wired up, still have abs if you want to reinstall)
new battery
magnaflow stainless exhaust cat(sounds mean)
INTERIOR
swapped beat beige leather for late black interior
swapped in 98 up dashboard & stereo(monsoon bose system sounds great)
98 up center console
98 trans am buckets in perfect shape & rear seat also
t-top shades(grey but can be dyed)
interior complete assembled all power options work except locks
thanks for looking
eddie
240-216-0063
95 z-28 106000
11.0-1 comp
shot peened rods
arp rod bolts
manley valves
all new sensors
taylor 10mm wires
new ac compressor
new ac lines
aluminum radiator
stock locking rear
traction bars
new strut boots
new steering rack
new battery
INTERIOR
