QUICK QUESTION! What type of steering fluid?
flexus
09-14-2007, 05:57 AM
I am replacing my rack and pinion assembly along with ends and i want to flush the old fluid and fill it up with new one, just i don't know what type and i couldn't find it anywhere.
I have a '96 v8, 16" rims, SS model.
I don't live in the US so i'll need some kind of universal type of steering fluid to find it here.
Also, how much is needed for a complete refill?
Thanks!
Dave89IROC
09-14-2007, 07:10 AM
automatic trans fluid will work if you can't locate P/S fluid
heck, it the US, the only kind of P/S fluid thats easy ti find it universal stuff
flexus
09-14-2007, 08:25 AM
Ok then, i'll get some ATF but how much is needed for a complete refill of the system?
n2ceptor
09-14-2007, 09:43 AM
Automatic Trans Fluid has detergents in it that wear out seals faster...... I would suggest just power steering fluid only....... JMO
Dave89IROC
09-14-2007, 05:22 PM
i never had any problems, hell, ATF has fixed seaping P/S hoses on more then one of my vehicles
and I would say 2 quarts/liters would be enough, if the system is completely empty
what types of P/S fluid are available to you over there?
n2ceptor
09-14-2007, 07:24 PM
Carquest power steering fluid (made by Warren Unilube INC)
Vavoline power steering fluid
Pyroil power steering fliud
dangalla
09-14-2007, 08:21 PM
yeah and most auto manufacturers recomend atf
Mtrhds94Z
09-14-2007, 10:42 PM
Valvoline SynPower is excellent PS fluid..
Dave89IROC
09-14-2007, 10:50 PM
guys, he's not in the US, so we are seeing what he does have access to , not what you use
Bayer-Z28
09-14-2007, 11:21 PM
I used Valvoline Synthetic... I had a problem w/ boiling my PS fluid when canyon carving.. I flushed the entire system and replaced it w/ that. It should take about a qt to do the entire system. I bled the rack down too..
n2ceptor
09-14-2007, 11:29 PM
What country???????
shoebox
09-14-2007, 11:58 PM
They do? The GM owner's manual (4th gens) says to use ps fluid.
I guess I would try ATF if I had absolutely no other choice. :shrug:
Bayer-Z28
09-15-2007, 12:30 AM
^ yep.. PS fluid.. I have fluid specs in my stickey in the LSx Room.. Right out of my owners manual..
flexus
09-16-2007, 05:23 PM
I've looked up on the internet and at some gas stations what was available, i found that pretty much anyone who makes car oils makes special PS fluids. Apparently PS fluids don't have types, they're universal for any car any system...
I've found 2+2 PS fluid 1/2 quart, about 6-7$.
I'm sure if i look more i'll find other types too. I am thinking of going for some PS fluid imo.
n2ceptor
09-16-2007, 05:33 PM
Hondas' and Toyotas' do have their own recommended type... But just about everyone else is universal, unless its an exotic.....:)
flexus
09-17-2007, 03:44 PM
I bought 1.5 quarts of 2+2 power steering fluid (Berkebile oil company). It sais on it: Meets saginaw steering gear division of general motors specifications numbers 9985010.
It's honey colored (yellow-orangeish).
Hope it's gonna run smooth :D
