Ok4thGen
09-13-2007, 03:09 PM
I ran a TnT plate setup on my old camaro, digital 6, window switch, fpss, was running a 100 shot
had a lean situation in both rear cylinders and melted off the end of the spark plugs and chunked them threw a valve and ruined the seat.
I did not have a different fuel pump but i was running good gas and also had it on a dyno with the n2o to verify the air fuel etc when on the spray everything was in the green but this problem happened.
This is all in the past but here lately ive been thinking about the bottle again,
my problem is im kind of scared to go with a non direct port system maybe im just being retarded.
but given the situation and the price differences what are the pros and the cons of the two setups, on a lt1 i really feel like itd be hard for each cylinder to get the same mix of nitrous and fuel as the others.
or maybe i should look at a normal setup with a dedicated fuel setup.
what is everyones opinions on this.
