Can you put Z28 sway bar in a V6?
mrmint69
09-13-2007, 12:51 PM
Can you take a 94Z sway bar and rear control arms and put them in a 99 V6? I don't even know for sure what the V6 has for them but i assume they are smaller and weaker. What all would i need like end links and bushings?
Greed4Speed
09-13-2007, 02:45 PM
I'd bet they're the same size unless the Z had the 1LE option.
94Camaro_Z_28
09-13-2007, 02:46 PM
I doubt the control arms will be any different. I don't know if there is any difference between the early 4th gens and the later 4th gens, but I easily put a v6 rear into my 94 Z28 with no issue when my posi went out.
The sway bar should bolt up...and I don't see a point in changing the control arms.
shoebox
09-13-2007, 03:06 PM
Sway bars and control arms should be swappable.
