Two stages and retarding the timing
Z-RATED94
09-02-2007, 02:28 PM
I'm not even done hooking up the nitrous yet, and I'm thinking of running a two stage set-up. ;) I'll be running the 685 ign. box with the Nitro Daves plate system. Maybe a 100 shot off the line. The car might be traction limited. Then how about another 50 once the car hits 2nd. Could something like a MSD retard box be wired in to the system to retard the timing another 2 degress or whatever it needs, once the 2nd stage kicks in? I was thinking a button on the steering wheel, to trigger the 2nd stage. Any draw backs to running two systems off of one bottle? Thanks, Rick.
JodyJ
09-02-2007, 11:51 PM
Take a look at the MSD Digital Multi-Retard unit (http://www.msdignition.com/tc_6.htm) I'm thinking about running run of these or maybe the FJO Nitrous Mini-Controller (http://www.fjoracing.com/products/2stageminicontroller/)
I have both systems, but they are not yet tried them. I'm leaning towards the FJO because of the ability to progressively bring in the 200 shot that I will be running.
I think with the suspension setup you have you'll have no problem hooking up on the 150 shot.
Jody J.
1982z28with18s
09-03-2007, 01:29 PM
You can retard the timing for the first stage via the IAT mod, and the 2nd with the box.
97formulakid
09-11-2007, 10:47 AM
IAT mod??
1982z28with18s
09-11-2007, 12:07 PM
You trick the iat into thinking it's a high temp, then in the tune, you change those cells to pull how ever much timing you wish. Do a search on ls1tech and you should be able to find more info on it.
