detail maintenancing
maro z28
08-27-2007, 02:28 PM
I wipe my car down at least 2-3 times/day with micofiber towels. Lately I've noticed lots of swirl marks in the clear coat. Not real visable except when light shines on it, then its real noticeable. My question is, does wiping a dry car down w/ dry microfiber towels put scratches in the clearcoat?
shock6906
08-27-2007, 03:20 PM
The microfiber itself doesn't, but the dust and dirt on the paint or trapped in the fibers does.
maro z28
08-27-2007, 05:13 PM
How can I detail b/t washes w/out messing with the clear coat?
PSU 98
08-27-2007, 06:18 PM
At the very least use a good quick detailer and microfiber towels. Many people like the California Car Duster for that purpose. There are some "waterless" car wash products marketed as well. I can't recommend any products specifically since I don't choose to clean that way :)
hcvone
08-28-2007, 07:23 AM
It could be the microfiber towels putting scratches in your clear coat, when you wipe your car down you are using a detail spray correct? If not that is probably where your scratches are coming from. Did you do a scratch test with your towels and a CD? If you just wipe your car down without detail spray it's like washing your car without car wash (plain water) there is no lube so the dust and dirt will scratch your finish, the use of a good detail spray will lift the dirt off the finish, and prevent scratching. :)
Brez
08-28-2007, 02:51 PM
hcvone Pretty much sums it up if you're paint is in good shape I would not be wiping it down 2-3 times a day. I agree with the saying ''I would rather see a dirty or dusty swirl free car than a clean swirled car''
Try this site for more info autopia.org
LaSSt One
08-29-2007, 03:57 PM
That's alot of wiping. You might need to invest in a California Car Duster.
Chrisz24
08-30-2007, 11:21 AM
Agreed!
Wipe it down every few days with a Cal car duster and if needed use some detail spray and micro fiber towills to clean it up. I dont use detail spray and micro fiber towills on the sides or behind the wheels between washings since even then you can still scratch it and move the dirt around, I just do the top panalls where it gets the most dust.
maro z28
09-02-2007, 02:08 AM
After it rains, I usually wipe it dry. Is that bad?
shock6906
09-04-2007, 08:57 AM
I would say it's bad, at least from the bolded text above. If you want to dry it off without messing up the paint, I'd say you should invest in a leaf blower.
MasterZ28
09-04-2007, 12:09 PM
EXACTLY, dust is a must before micro rubbing it, also try sprqaying very lightly the towel with liquid detailer for an even more brilliant glaze.
Chrisz24
09-04-2007, 08:02 PM
I wouldnt! Unless it was just washed and not driven since and absolutely needed to be dry.
When you drive in the rain the road grit, sand and water stick to the dust on your car, thats why they look dirty after a rain. Wiping it down is just spreading around the grit. I find that if it rains the car drys better on it's own without spots as long as it has some wax on it.
Geezer powered
09-05-2007, 02:10 PM
Honestly With A Black I'd Just Wash And Wax It Once A Week. Thats What I Do And Have No Promblems.
Chrisz24
09-11-2007, 01:43 PM
You wax your car weekly?:confused:
