Autocross and Road Racing Technique There is more to life than a straight line
DMS springs... handling abilites?
Old Dec 2, 2002 | 03:33 PM
MustangEater82's Avatar
I see they are a great price and lower the car abotu a 1.3 in. which might help a bit but does anyone know the spring rates and if they are significanlty better then stock and compare to any other aftermarket springs.
Old Dec 2, 2002 | 09:21 PM
94bird's Avatar
Comparing the DMS vs Eibach Pro:
............................Front................. ...Rear
DMS..................325-630 lb/in...........95-160
Eibach Pro..........377-600..................94-160
The DMS rates don't sound bad to me, but you can't tell from these specs if the change in rate is similar between the springs. I'd suspect it's not very different.
Old Dec 2, 2002 | 10:06 PM
2002Z28SSConv's Avatar
I haven't heard of them being available for the V6's Eric. Your front end will probably sit kinda high.
But I've been wrong before.
Old Dec 3, 2002 | 02:25 AM
yeha I know that is something I ahve to look out for I was jsut making sure they were not an appearance only mod that they did have some handling properties befoe I start digging. And I have also considered the thought of putting spacers in the rear, to jack the rear up so maybe I woudl be lowering my car, and raisnig an in. all at hte same itme? The idea is kinda out there, I could care less if my car was lower or not I am more interested in stiffere spring rates and I am sure they will be an improvemtn over stock v6 springs and stock v6 springs with over 120k on them.
Old Dec 3, 2002 | 12:21 PM
V6Bob's Avatar
Post
I've seen you post about autocross. Springs, swaybars, and shocks all need to be matched to get the best car for that. Why not get a pro (I'd use Sam Strano, but it's a personal decision) to recommend a package?
Otherwise you could waste a lot of money and time. Global West says it, and it's so true:
"Compatibility is a key issue because of so many aftermarket companies offering suspension components. It is easy to purchase non-compatible components and end up with unacceptable results."
Old Dec 4, 2002 | 02:25 AM
I agree....
but part of working on my car is I like to work it my own way and make my own deceisions... I highly doubt it will competitive enough to dump huge sums of money, main reason I stay away form springs and shocks is its oging to cost me a good $350, for slp takeoffs, and a eibach kit.
I can't afford that... in the end money = competitiveness.
but these DMS springs ae $150, I was looking into if they were a decent quality performance part, not jsut a set of lowering springs to make your car look nicer at a car show. Most my shock questions have been related to whats on my car at the moment, decent performance shocks are going to run me ~$200.
I know there are better setups I am looking for a decent setup with what I can afford.
Old Dec 4, 2002 | 07:15 AM
chuck's Avatar
Bilsteins with your stock springs will be faster than SLP takeoff DeCarbons with _________ aftermarket springs.
Old Dec 4, 2002 | 12:40 PM
V6Bob's Avatar
"I know there are better setups I am looking for a decent setup with what I can afford."
I'm no pro, but why not put a V8 suspension on? SLP takeoff shocks (people sneer, but they're a good deal for $50), springs and bars from SLP or a junkyard. Less than $200 for parts. At least you know they were engineered to work together.
It's not flashy, but it's gotta be a lot better than what you've got, especially with your old and mismatched shocks.
Old Dec 4, 2002 | 12:48 PM
Soma07's Avatar
Cool
Well the first thing I would do is invest in a bottle of car wash.
I saw you car in the parking garage the other day and I'm sure it'll be quicker if you wash the 10lbs of dirt of it
Old Dec 5, 2002 | 02:08 PM
I already have sways, my thinking was to go with SLP takeoff shocks, and maybe DMS springs, if they are only going to cost me rougly $50 mroe then stock z28 srpings, and have better spring rates.
And with any spring off a v8 car its going to raise my nose roughly an in. my thinking was maybe get hte DMS, since they lower the car about 1.3in. and maybe run a spacer in the rear spirngs and keep the car roughly the sae ride height, maybe a slight lowering, instead of with takeoff v8 springs whcih if I did the same thing to keep the fornt and rear of my car balanced it woudl in fact raise my car higher then the stock height. Which woudl not be optimal.
and Jason, car is getting a wash today, hopefully , I plan on going to OSW Friday night and MSCC event on Sunday, you going to either?
Old Dec 5, 2002 | 04:27 PM
Soma07's Avatar
I'll probably be out at Palm Bay on Sun. I have my last final tommorow at 7:00 so that rules out OSW. I probably wouldnt go anyways, I havent been out there in ~6mo and I cant say I miss it.
Old Dec 5, 2002 | 05:08 PM
blue95's Avatar
this help any?
http://angelfire.com/my/fastcar/suspension.html
Old Dec 6, 2002 | 08:35 AM
gasp.... someone with an f-body that doesn't miss the drag strip?
I know what you mean it is kind of a waste, but I am so close to be fastest 3.4L N/A, jsut wanna get it done. Its friday trying to see if I can figure a way to run a belt only on waterpump and crank.
Old Dec 10, 2002 | 08:46 AM
v7guy's Avatar
FWIW when I got mine they said they were JAMEX, it was stamped right on the spring....some info you might want to be aware of
football4life
Oct 4, 2015 07:48 AM
tommalcolm
Sep 11, 2015 03:39 PM
cohopefull
Sep 8, 2015 03:22 PM
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
