Replacing rear wheel stud on Tracton Control car?
Old Aug 17, 2007 | 08:52 PM
Gtpguy's Avatar
I've done a search and know how easy it is to do on a car w/o Traction control, but couldn't find a single how-to on a car with traction control.
For those that don't know about TC cars, there is a large gear looking thing within an inch behind the hub. So getting a stud in there, is physically impossible.
So how does one do this w/o removing an axle, which I can do, but it's messy as hell.
Old Sep 12, 2007 | 02:30 PM
nb 96 z's Avatar
Did you figure out how? I've got traction control and have the same problem. What did you do to fix this?
Old Sep 12, 2007 | 08:17 PM
Gtpguy's Avatar
I think we will both have to remove the axles. I've searched and got no answers. Nor did I do it yet. I'll do it when I swap to 3.73s.
Old Sep 13, 2007 | 06:50 PM
nb 96 z's Avatar
http://web.camaross.com/forums/showt...96#post4866796
Check this out. I'll be trying these suggestions to see if it works as soon as I have a day off.. Worth a try since messing w/the axles would be a pain. Hope this helps.
Old Sep 13, 2007 | 10:33 PM
Gtpguy's Avatar
Good luck. Let me know what happens. I'm under the impression the LS1 rear, although interally the same as an LT1, the ABS and braking system is entirely different.
thenewkid
Nov 27, 2014 09:41 AM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
