Anyone tried the wheel paint from dupli-color?
Old Aug 17, 2007 | 07:30 AM
Jeremy95LT1Form's Avatar
Noticed the dupli-color paint can the other day while in Autozone. They say there for painting your rims? Noticed it comes in black. Always wanted black rims for my Formula. The stock rims look ok, but would look better black. Plus it would be cheaper then buying new rims/tires. Guess it would turn out ok if I took my time and sanded the rims first?
Anyone tried this stuff yet? I don't want to get started on this project to have it turn out like crap.
Old Aug 18, 2007 | 03:53 PM
Greed4Speed's Avatar
Any black will work. Don't waste the extra $ for the "wheel" paint. Prep is where you make the difference. Spend the extra $ there.
Old Aug 18, 2007 | 06:49 PM
NemesisLT1's Avatar
i just painted my rims black today...
Old Aug 20, 2007 | 07:56 AM
I was thinking about using the black engine block paint as it holds up to high temps and has to be pretty resistant to chemicals and chipping. Would that work or would it look like garbage?
When it comes to prep work I was just going to sand it down, lightly, with probably 320 grit paper and make sure it was good and clean with a good electrical parts cleaner that would remove all oil/buildup and not leave a residue. Am I going in the right direction here or is there something else I should be doing instead. Never tried this before.
Thanks,
Jeremy
Old Aug 20, 2007 | 08:25 PM
I sanded mine down, cleaned it with acetone then alcohol and used tack cloth. I used the Cast iron gray engine enamel. I lasted for a couple of years until I got tired of it and stripped off all the paint and went for the 35th anv wheel look. I didn't even clear coat over it, but it wouldnt hurt.
Old Aug 24, 2007 | 09:41 PM
Interceptor1's Avatar
I tried the Duplicolor wheel "High Performance Coating" aluminum paint on the wheels of a car I was selling. The finish didn't look bad, but seemed a bit rough, not glossy. Anyway it made the car look better.
Then I tried the same aluminum wheel paint, but adding on top the Duplicolor high performance coating clear for the hubcaps of my wife's car. It was difficult to get an even finish, because if I added one extra pass of clear, the area would look darker than the rest. The finish was also a little rough, not that glossy and not very durable, it later stained with cleaning solutions.
I am trying to find a brand of aluminum color paint that doesn't look too shiny and is durable so I can touch up my salad shooters...
Old Aug 24, 2007 | 10:06 PM
er-z's Avatar
heres my car with painted rims http://web.camaross.com/forums/showthread.php?t=539619
Old Aug 26, 2007 | 06:48 AM
The painting will being as soon as it stops raining up here.
Thanks for the assistance
JCS
Old Aug 26, 2007 | 07:18 AM
Get some engine enamel. I like how the Duplicolor with ceramic in it goes on.
Old Aug 26, 2007 | 10:12 AM
adamc's Avatar
just got done doing my calipers with the duplicolor red caliper paint it had the ceramic in it it seemed to do pretty good id say some high temp paint with ceramic would work well on the wheel as well
i was origionally going to get the engine paint but got the caliper paint because i liked how the color looked better (tested both)
Old Aug 26, 2007 | 06:20 PM
Fuels94TA's Avatar
Ditto...I used satin black, with high heat clear. It came out very good on my C5 wagon wheels. There are two pixs in my website on the last page.
Vinny
Old Sep 4, 2007 | 11:45 AM
Prep?
My only question before I get to painting. What steps should I follow for prep before the paint begins to fly?
Old Sep 4, 2007 | 12:17 PM
If you original paint is good, rough it up and clean it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bowtieboy95
Jul 1, 2015 06:49 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
