Rear Center Brake Hose
agent z28
08-16-2007, 10:31 PM
The rear center brake hose for my '93 Z has been discontinued by the aftermarket, though the hose for the v6 model with rear drums is still available. Looking at the Raybestos catalog for '94 and '95 showed a center hose for LT-1 cars that carried the same part no. as the disc/drum setup for that year. So, would it be safe if I order the disc/drum hose for a '93 F-bod? Is there any difference in hoses among the various years?
hotpart
08-16-2007, 10:59 PM
The hoses are different between the two. The V6 drum brakes use a 7/16 female inverted seat on the chassis side and the rear disc setup uses a M12 drill point seat on the chassis side, the axle side is the same between the two. The good news is we still make the rear center hose for the non traction control and traction control cars using Teflon lined stainless braided hose.
http://www.hotpart.com/images/products/20070627232405_big.jpg
This is the link to the brake hose page. (http://www.hotpart.com/index.php?&keyword=%20by%20Keyword&p=search&cat_id=30&manuf_id=3&submit_x=74&submit_y=15&PHPSESSID=9c261fa56e952046b9a16e7d6c30a9ed&catcount=42&cat_id=30&sub_id=70&catcount=)
agent z28
08-16-2007, 11:38 PM
Whew! Thanks for the reply with clarification! I just ordered the hose through your business.
hotpart
08-18-2007, 11:48 PM
Thank you for the order. Your hose shipped out last week and you should have received a tracking number. If you did not receive it PM me and I will get it emailed over to you again.
