htweels86
08-15-2007, 10:54 PM
Hi all,
I'm installing B&M's Transmission SuperCooler #70268 for my 4L60E equipped '94 Z28.
My question is does it matter which direction the cooler line fittings are facing when installed? For example if both fittings are facing down will the ATF still be able to flow thru the cooler properly? I would just install it so the fittings are facing towards the passenger side but there's not enough clearance to get the zip-ties thru the cooler holes @ the top & then put the locking tabs on...
