grinding?
gpss97
08-14-2007, 08:19 AM
ok. just curious if its time to change the fluid or maybe its got air in it. but heres my problem.
when i drive normal the gears go in normal, no grind no problems, but when i get on hit half throttle to full throttle going into second grinds with clutch all the way to the floor.
its has new clutch and everthing in there, just got out of the tranny shop, thought it was the clutch causing it before so put a new one in, and still the same problems.
so could it be one of the two problems i'm thinking, air or old fluid?
thanks for reading
mike
