Which coil delco or aftermarket
jeffwof1z28
08-10-2007, 09:18 PM
Wondering what others recommend for coils for the 96 lt1. Mine is starting to fade, should I replace with a delco? or aftermarket? Any opinions would be appreciated.
shoebox
08-10-2007, 11:22 PM
The stock 96 coils are pretty good. What evidence do you have yours is "fading"?
jeffwof1z28
08-11-2007, 03:45 PM
Hi thanks, At low rpm's, say goin from 35 mph in 5 th gear accelerating staying in 5th to freeway speed it has some hesitation till the rpm's build a little higher. I've changed the plugs optispark dist and rotor, replaced with new delco plat wires. So I pretty much narrowed it down to the coil. Am I right??
shoebox
08-11-2007, 04:12 PM
Possibly. It is not easy to judge the output of the coil, unless it is suitably weak. The upside is that it is not expensive to replace. :)
stopthatman
09-18-2007, 05:02 PM
and the wires make a big difference
